98+ JDM ITR into DB2... Q's.
Ok, heres the story. I currently have a DB2 (93 Integra GSR) and I am looking to ditch my current LS/Vtec setup and go with a 98+spec JDM ITR motor + Tranny. This is what I have figured out so far.
<U>Transmission (Mine is cable, ITR is Hydro) -</U>
Innovative Mounts Cable to Hydro Conversion Kit
<U>Mounts - </U>
Would I be able to use Existing 93 GSR Mounts?
<U>Electrical - </U>
What all needs to be done in this sector? What do I need to do to get the ECU to plug in? It is currently wired for LS/Vtec and has an OBD1 LS bottom end with JDM OBD1 B16 Head.
<U>Alternator -</U>
Will it plug in?
<U>Starter -</U>
Plug in?
<U>Clutch-</U>
Would I be able to use my existing clutch on the car (ACT Xtreme PP with Street Disc) Currently on the YS1 Short Gear Tranny. I heard that this tranny has the bigger splines accompanied on the B series Hydro Tranny.
<U>Axles / Halfshalf -</U>
Re-Use Stock ones?
Thanks for the help in advance.
Jared.
<U>Mounts - </U>
<U>Alternator -</U>
Will it plug in?
<U>Starter -</U>
Plug in?
<U>Clutch-</U>
Re-Use Stock ones?
Jared.
QUESTOYZ by RHanDy
Mar 25, 2004 06:58 PM
