90 Accord front balance shaft seal help
is their any tutorials on how to take the old one out and put the new one in, or atleast can some one help and tell me were exactly it is ??? photos would be very helpful
The balancer shaft is on the right side of the engine.
looking at the timing belt area with the covers removed it is just above the crankshaft and beside the water pump.
Also be sure you get the seal retainer when you replace it
Another question, in the Haynes manual it sugested removing a bolt to acess the ballancer, then inserting an allen wrench to lock the gears so the crank can't turn, I did this and now a a bent allen wrench stuck in the front of the engine cover that I can't get out, now what?
This link might help you, the Lude has the same block set up, except the tensioner
http://members.troublecodes.ne...t.htm
The bolt is not reverse thread. Turning it to the left will loosen it. Take a breaker bar with lots of extension and set it up on a jackstand. Put a cheater pipe to the breaker bar and stand on it. You will hear something break. Check to see if it broke the bolt loose or just some of your tools and repeat until you get it. Good luck.
brycarp
Nov 21, 2010 10:39 AM
DelSolMaker
Jan 13, 2008 07:13 AM
