87mm pistons for a B20-sleeved block?
Old Oct 18, 2006 | 06:51 AM
VVV's Avatar
VVV
Default 87mm pistons for a B20-sleeved block?
Anyone done it successfully yet? Reliability?
Old Oct 18, 2006 | 06:54 AM
xDicktonesx's Avatar
Default Re: 87mm pistons for a B20-sleeved block? (kstmotorworks)
good luck getting a HG to seal for more than a run or 2. but id like to know as well.
Old Oct 18, 2006 | 07:53 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kstmotorworks &raquo;</TD></TR><TR><TD CLASS="quote">Anyone done it successfully yet? Reliability?</TD></TR></TABLE>
you can get a custom head gasket for this setup from cometic. i doubt you'll have any sleeve left if you need to rebuild the motor when you blow your head gasket
Old Oct 18, 2006 | 08:57 AM
Forrest Gump 9's Avatar
Default Re: 87mm pistons for a B20-sleeved block? (acydphryck)
Who car about head gasket. Just weld the head and the block together.
Old Oct 18, 2006 | 09:54 AM
d16dcoe45's Avatar
Default Re: 87mm pistons for a B20-sleeved block? (Turbo9Nut)
Yeah getting the parts for the 87mm is obviously not the issue--the issue is that the HG will have trouble holding more than 2-3 full tilt runs.
Old Jul 24, 2007 | 05:56 PM
oxSLEEPERxo's Avatar
Default Re: 87mm pistons for a B20-sleeved block? (Forrest Gump 9)
up for more opinion
Old Jul 24, 2007 | 08:53 PM
doood's Avatar
been there done that
Default Re: 87mm pistons for a B20-sleeved block? (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">up for more opinion</TD></TR></TABLE>
if you're building a race engine, knock yourself out. if not, dont bother.
Old Jul 30, 2007 | 03:37 PM
Lubo_25's Avatar
Default Re: 87mm pistons for a B20-sleeved block? (VVV)
max. safe bore on a b20 is 85mm, 87mm is prelude territory only...would be nice though
Jdmb16sir2
Oct 26, 2007 12:23 PM
greasemonkee
Oct 13, 2005 10:57 AM
Option
Dec 28, 2004 04:45 PM
fknfast
Mar 1, 2004 07:23 PM
TwoKSiR
Sep 11, 2003 06:17 PM
