Ask your H22 Questions Here (Technical Only)
Old Oct 18, 2006 | 04:10 AM
Adam.'s Avatar
Default Ask your H22 Questions Here (Technical Only)
Since we can't seem to keep the other thread 100% technical, I created a new non-tech one in GDD that can be found here:
https://honda-tech.com/zerothread?id=1785058
As for Technical Questions, feel free to post them here
Old Oct 18, 2006 | 06:57 AM
no_friends's Avatar
Quick question. Can the tps cause the throttle to break up and cut back as you lay in to the gas? Thanks.
Ryan
Old Oct 18, 2006 | 07:01 AM
Turbogixxer's Avatar
Default Re: (no_friends)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no_friends &raquo;</TD></TR><TR><TD CLASS="quote">Quick question. Can the tps cause the throttle to break up and cut back as you lay in to the gas? Thanks.
Ryan</TD></TR></TABLE>
Yes, if it is giving weird voltage to the ECU. Check the TPS, it should be under .5 at closed throttle, ~4.5 at WOT.
Old Oct 18, 2006 | 01:00 PM
no_friends's Avatar
Thanks alot turbogixxer for helping me fix my problem. Runs great now!!!
Ryan
Old Oct 18, 2006 | 02:16 PM
SIXTY's Avatar
can the plug on a jdm h22 distributor be depinned? I have done this many times with d and b series distributors. I ask because i am in the middle of switching from b to h and cant seen to depin the wires from either side of the plug. I really dont want to cut and splice. Thanks in advance.
Old Oct 18, 2006 | 02:22 PM
Default Re: (SIXTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY &raquo;</TD></TR><TR><TD CLASS="quote">can the plug on a jdm h22 distributor be depinned? I have done this many times with d and b series distributors. I ask because i am in the middle of switching from b to h and cant seen to depin the wires from either side of the plug. I really dont want to cut and splice. Thanks in advance.</TD></TR></TABLE>
Yes, it uses the same as OBD1 B/D series.
Old Oct 18, 2006 | 02:45 PM
SIXTY's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, it uses the same as OBD1 B/D series.</TD></TR></TABLE>
i know the wires are the same, but why cant i pull the wires out of the plug. I try to use the same technique as i do with b and d series, by using a small pin or a nail to pop the pin out of the plug, but the wires dont budge.
Old Oct 18, 2006 | 02:52 PM
Default Re: (SIXTY)
i know the wires are the same, but why cant i pull the wires out of the plug. I try to use the same technique as i do with b and d series, by using a small pin or a nail to pop the pin out of the plug, but the wires dont budge.</TD></TR></TABLE>
Yeah, it is the same plugs.
Sometimes JDM connectors (I guess they sit without someone messing with them) are tough to pull the pins out.
I pull the white covering off, then push up and in with the pin, it always comes out without a problem.
Old Oct 18, 2006 | 03:57 PM
turtleman321's Avatar
what year and car do p13 ecu's come in?
Old Oct 18, 2006 | 04:13 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (turtleman321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">what year and car do p13 ecu's come in?</TD></TR></TABLE>Honda Prelude VTEC 92-95. Not sure about 96..
Old Oct 18, 2006 | 05:02 PM
H22EKHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no_friends &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot turbogixxer for helping me fix my problem. Runs great now!!!
WoW so I guess these H22 question threads are a valuable asset to the Honda-tech community,......
back on track...
Old Oct 18, 2006 | 05:50 PM
93.2's Avatar
Default Re: (H22EKHATCH)
i leave for 3 days. and this happens
anyway. could bad grounds cause the alternator to spark?
Old Oct 18, 2006 | 06:03 PM
Default Re: (g-wagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-wagon &raquo;</TD></TR><TR><TD CLASS="quote">i leave for 3 days. and this happens
anyway. could bad grounds cause the alternator to spark? </TD></TR></TABLE>
Maybe, or it is shorting internally
Old Oct 18, 2006 | 06:07 PM
SIXTY's Avatar
I pull the white covering off, then push up and in with the pin, it always comes out without a problem.</TD></TR></TABLE>
that is what i was looking for. Did not know that those came off. Everything all good now
Old Oct 20, 2006 | 01:37 PM
SIXTY's Avatar
Default Re: (SIXTY)
can i use an h23 waterpump on an h22 if i use the h23 timing belt. I got an h23 waterpump because that is all i could get, noone has one in stock around here. It looks identical, all the bolt holes, castings etc, the only thing is the gear is smaller. Anyhelp would be appreciated.
Old Oct 20, 2006 | 03:02 PM
Default Re: (SIXTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY &raquo;</TD></TR><TR><TD CLASS="quote">can i use an h23 waterpump on an h22 if i use the h23 timing belt. I got an h23 waterpump because that is all i could get, noone has one in stock around here. It looks identical, all the bolt holes, castings etc, the only thing is the gear is smaller. Anyhelp would be appreciated. </TD></TR></TABLE>
You should be able to, I have never tired it, so take it with a grain of salt.
BTW, you try the other dealership around you. Some dealers can a bigger instock parts then others
Old Oct 20, 2006 | 06:35 PM
UltimX's Avatar
What would be the compression on a H22 block, f22 crank, f22 rods, and type s pistons? Would the piston even clear the head?
Old Oct 20, 2006 | 08:11 PM
93h22hatch's Avatar
Default Re: (UltimX)
i have a question,i have an h22 in a 93 eg hatch and i am in need of some new wheel bearings i was wondering if i should go with the stock civic ones or do i need to go with a beefer set?
Old Oct 20, 2006 | 08:32 PM
DC4_MADMAN's Avatar
Default Re: (93h22hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have a question,i have an h22 in a 93 eg hatch and i am in need of some new wheel bearings i was wondering if i should go with the stock civic ones or do i need to go with a beefer set?</TD></TR></TABLE>
Stock civic wheel bearings are fine, go OEM.
Old Oct 20, 2006 | 08:35 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">What would be the compression on a H22 block, f22 crank, f22 rods, and type s pistons? Would the piston even clear the head?</TD></TR></TABLE>
12.12:1 and the piston will be .020 out of the bore.
Old Oct 21, 2006 | 02:09 PM
UltimX's Avatar
Default Re: (DC4_MADMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4_MADMAN &raquo;</TD></TR><TR><TD CLASS="quote">12.12:1 and the piston will be .020 out of the bore.</TD></TR></TABLE>
Just 12.1:1? Thats gay! The jdm h22a gives a higher ratio than that. I was hopeing for around 13 or so. thanks for your help man!
Old Oct 21, 2006 | 04:23 PM
Hotori Hanso's Avatar
If i put a h22 into a crx, want to get BAR'ed and run OBD1; do i have to get a h22a1 or can i put in a h22a4?
Old Oct 21, 2006 | 11:16 PM
2point2's Avatar
Default Re: (Hotori Hanso)
Technical Only? ok..
Q: What will a stock h22a run in a CRX with a T3/4 w/9psi spring (vac line to turbo)
A: 11.8 first run, 11.6 second run.
Thanks for all the help in the previous h22 threads guys. subscribed.
Old Oct 22, 2006 | 07:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hotori Hanso &raquo;</TD></TR><TR><TD CLASS="quote">If i put a h22 into a crx, want to get BAR'ed and run OBD1; do i have to get a h22a1 or can i put in a h22a4? </TD></TR></TABLE>
If you go OBD1, you wold have to get a H22a1 because if you swapped in a h22a4, you would have to do OBD2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">Technical Only? ok..
Thanks for all the help in the previous h22 threads guys. subscribed. </TD></TR></TABLE>
No problem. Props to the tuner of the car!
Old Oct 22, 2006 | 09:36 AM
I heard that OBD1 is better for tuning, can someone confirm this.
If so, what are the advantages of tuning over a OBD2 car?
