ARP Rod Bolts!
Old Oct 17, 2006 | 09:08 PM
joshEK9's Avatar
Default ARP Rod Bolts!
I got a set of 1.8 GSR ARP rod bolts and was wondering if anyone knows if you can use those with 1.6 B16 Rods?
Old Oct 17, 2006 | 09:37 PM
joshEK9's Avatar
Default Re: ARP Rod Bolts! (joshEK9)
Come on, I'm sure someone knows.
Old Oct 18, 2006 | 08:10 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshEK9 &raquo;</TD></TR><TR><TD CLASS="quote">I got a set of 1.8 GSR ARP rod bolts and was wondering if anyone knows if you can use those with 1.6 B16 Rods?</TD></TR></TABLE>
if the rod bolts are used, i recommend not re-using them. also, you'll need specific 1.6 ARP rod bolts for use with the B16 rods...just to have peace of mind. a good machine shop can hang the B16 rods on those GSR rod bolts but you'll be loosing quite a bit of material on the rods by doing this. reliability becomes an issue when the motor revs high.
Old Oct 18, 2006 | 08:43 AM
Furyof4's Avatar
Default Re: ARP Rod Bolts! (acydphryck)
All bvtec use the same arp part#. If they are new then use them. Just make sure you have a machine shop install and check the rods afterwards.
Old Oct 18, 2006 | 08:45 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: ARP Rod Bolts! (Furyof4)
True story.
All B-series VTEC rod bolts are the same.
The difference is between VTEC/nonVTEC rod bolts. (size)
Old Oct 18, 2006 | 09:22 AM
joshEK9's Avatar
Hey thanx alot man, they are used so on that not Im just going to junk them.
Jordb22
Jan 31, 2012 08:37 PM
ProJectCvic
Mar 13, 2007 06:52 AM
neyrod
Feb 16, 2005 11:05 AM
