ats 3,4,5 + 4.785 / 4.400
have anyone tried ATS 3,4,5 with JDM 4.785 for a stock R motor?
is this setup good for a stock motor? or it will end the fun fast from revving the engine?
i will be installing Skunk2 Pro1 into this motor soon, so...do u guys recommand putting back the 4.4 or 4.785 after cams installed and before cams installed?
if u are going to use the ATS 3-4-5 gears, use the 4.4 final drive
if you use the 4.785 final drive, your top speed will be under 200kph and your cruising rpm's are going to be uncomfortably high
turbodsmpower
Jun 29, 2003 07:30 AM
DAMAGE DONE!
Nov 7, 2002 09:19 AM
