help lowering 60' times
Old Oct 17, 2006 | 06:34 PM
tyrone27's Avatar
Default help lowering 60' times
I'm runing 2.5 60' times with drag radials but my 1/4 mile is 13.8@109. I'm preloading the tranny and going at 4800RPM. anyone have any tips on how to lower my 60' times?
Old Oct 17, 2006 | 07:43 PM
Tippyman's Avatar
Default Re: help lowering 60' times (tyrone27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone27 &raquo;</TD></TR><TR><TD CLASS="quote">I'm runing 2.5 60' times with drag radials but my 1/4 mile is 13.8@109. I'm preloading the tranny and going at 4800RPM. anyone have any tips on how to lower my 60' times?</TD></TR></TABLE>
I was cutting 2.3's on shitty *** street tires and only getting 15.5 @ 90. You need to launch lower. I launched at around 2000 rpm and lsipping the clutch.
Old Oct 17, 2006 | 08:19 PM
TurboLSVtecTeg's Avatar
Default Re: help lowering 60' times (Tippyman)
What kind of tire pressure and what brand/size radial?
Old Oct 17, 2006 | 09:05 PM
one slow coupe's Avatar
Default Re: help lowering 60' times (TurboLSVtecTeg)
You need to lower the tire pressure most likely, do a good burnout. And If your not spinning launch higher.
for me i would do a second gear burnout.
launch at 7,000 on the 2step
cut 2.0 60'
Old Oct 18, 2006 | 02:12 AM
tyrone27's Avatar
Default Re: help lowering 60' times (one slow coupe)
Nitto drag radials at 17psi. 205/55/14
Old Oct 18, 2006 | 07:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone27 &raquo;</TD></TR><TR><TD CLASS="quote">Nitto drag radials at 17psi. 205/55/14</TD></TR></TABLE>
try lowering the pressure to like 12.. it might help
Old Oct 18, 2006 | 02:11 PM
gsp ej1-em1's Avatar
i ran a 14.2 . with 2.0 60 ft.
i was on toyo proxes t1r.
Old Oct 18, 2006 | 03:38 PM
fmfkid250's Avatar
dont be scared to drop them down to like 7-8, with a decent burnout, you mph is crazy high for that time,
110mph should be good for at least a mid 12
Old Oct 19, 2006 | 10:51 AM
tyrone27's Avatar
Default Re: help lowering 60' times (fmfkid250)
i'm goin gto try that. I'm going to start at 12 and work my way down
Old Oct 19, 2006 | 08:10 PM
1 2 NV's Avatar
best advice, learn to drive.
Old Oct 20, 2006 | 11:20 AM
tyrone27's Avatar
Default Re: help lowering 60' times (1 2 NV)
trying too
Old Oct 20, 2006 | 02:00 PM
fmfkid250's Avatar
try launching at like 3k
and dont give it all the gas sorta ease into it,
there is no excuse for a 2.5, seat time and getting used to the car is what u need
Old Oct 20, 2006 | 02:01 PM
1 2 NV's Avatar
im just being the obvious dick. you need to tell us whats happening. we cant just sit there see your 60' time and guess whats going on in the car when you launching it. more info is needed.
when i had DRs all motor id launch at 5.5-6k and just dump the clutch. ran 2.0 60s in my 2500lb coupe with B18c1, ITR cams, 3" short ram, ITR ECU, DC 4-2-1 header and exhuast.
ran 1.9s on those same DRs in my light *** hatch when it was a street car with more done to the motor.
Old Oct 20, 2006 | 07:52 PM
crawlin's Avatar
yeah im with fmfkid on this one im finally getting some decent launches 2.0 pretty consistant still 2.0 arent really that great i would like to see some 1.8xxx but yeah i usually dump it around 4k or so and ease into the throttle a little bit then when i feel it strat to catch i nail it and ive been getting better almost every time it just takes about 10-15 passes or so to start running consistent good times
Old Oct 27, 2006 | 12:24 PM
boostedbseries2000's Avatar
I launch @5k rev to 5 and dump it and pull 1.9 on DR, works for me
95ITRJDM
Dec 9, 2011 12:16 PM
cmasonrun
Nov 1, 2007 06:14 PM
vaporboy12
Mar 9, 2007 06:44 PM
quis84
Sep 18, 2005 04:29 PM
94_civic_guy
Aug 18, 2003 04:45 PM
