Help with wiring P28 ecu to my Si??? Couple questions................
Old Oct 17, 2006 | 04:16 PM
Xemu's Avatar
Default Help with wiring P28 ecu to my Si??? Couple questions................
Ok I'm stupid when it comes to this stuff so please be patient with my dumb ***.Originally I was planning on swapping out my Civic to OBD1 from OBD0 well my plans have changed.I now have an 88 CRX Si and was wondering what I need to do to wire up my P28 ecu to the Si?? I have the jumper harness which clips my Si ecu plugs into my p28 but I'm lost from there.Any help would be appreciated.
Old Oct 17, 2006 | 04:32 PM
Xemu's Avatar
Default Re: Help with wiring P28 ecu to my Si??? Couple questions................ (Xemu)
I can't go by the DPFI-MPFI swap directions because the wiring/colors are different right???
Old Oct 17, 2006 | 05:38 PM
HondaPartsHero's Avatar
Technical Hero
you'll need to wire up from the VTEC solenoid and VTEC pressure switch to the ECU. You'll also need to either depin the plug going to your distributor and use an OBD1 grey plug or use a OBD0-OBD1 distributor adaptor. Also you can use the SI fuel injectors and keep the resistor box or just use the Z6's injectors and eliminate the resistor box.
Old Oct 17, 2006 | 07:53 PM
Xemu's Avatar
Default Re: Help with wiring P28 ecu to my Si??? Couple questions................ (HondaPartsHero)
Ok maybe this will let you better understand my dilemma.When I plug this harness into my CRX clips in the cabin and then connect it to my p28 am I good to go?? What else do I need to wire?? I have this type of harness in the pic only I don't have the firewall connector so I have like 10 wires that I don't know what to do with.Are these the wires used for the V-tec and O2 sensor maybe????
Old Oct 17, 2006 | 07:55 PM
NikoZai's Avatar
There are instructions, call Rywire - we can walk you through anything. I'm available at 9am tomorrow morning into the night. talk to ya soon ~ Peter
Edit: Ah screw it call me now, NCIS is over.
Instructions: http://rywire.com/store/faqdes...id=22
Modified by NikoZai at 9:58 PM 10/17/2006
Old Oct 17, 2006 | 08:22 PM
JUN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote">Ok maybe this will let you better understand my dilemma.When I plug this harness into my CRX clips in the cabin and then connect it to my p28 am I good to go?? What else do I need to wire?? I have this type of harness in the pic only I don't have the firewall connector so I have like 10 wires that I don't know what to do with.Are these the wires used for the V-tec and O2 sensor maybe????
Yes, these wires are used to connect the vtec solenoid, vtec oil pressure sensor, 02 sensor, knock sensor (if you engine uses any), and some other choices that you might need or might not......
Old Oct 17, 2006 | 10:17 PM
Xemu's Avatar
Default Re: Help with wiring P28 ecu to my Si??? Couple questions................ (JUN.)
Does anybody know what the wires are for?? These are the colors of the wires:
1.Purple
2.White/Blue
3.Yellow
4.Blue/Black
5.Black
6.Orange/Blue
7.Red/Green
8.Green/Black
9.Gray
So 9 wires total can anyone give me a heads up on what these get hooked up too?? It would save me a ton of time not to mention make me feel real cool that I wired them up my self!!! Thanks guys!!
Old Oct 18, 2006 | 01:28 AM
Xemu's Avatar
Bump
Old Oct 18, 2006 | 04:29 AM
spiceisler's Avatar
As stated above: these are the instructions
E_F_9's Avatar
Dude just call Rywire and they will be able to answer everything.
joey6098
Jul 29, 2011 02:20 PM
four20jnd
Aug 30, 2006 06:01 PM
4dOoR-Ex
Aug 8, 2006 07:55 PM
r30slick
Mar 8, 2002 08:01 PM
r30slick
Mar 8, 2002 04:29 PM
