PC 800 misfire/ ignition problem
Old May 4, 2002 | 10:49 AM
Nighthawk S's Avatar
Default PC 800 misfire/ ignition problem
I bought a 89 Pacific Coast, and it has a strange problem.
The bike has four plugs(2 per cyl)controlled by two coils, one for the front plugs and one for the rear plugs. the bike runs reasonably well on the rear coil only, but backfires and misses badly when the front coil is hooked up.
I'm not sure exactly what the problem is, the coils are hooked up correctly as near as I can tell, and it seem to me that the front and rear coil for each cylinder should fire about the same time to get a full burn of fuel, but obviouly something isn't right.
Anyone have a similar experience with a PC 800, a Shadow 800 which uses the same engine set-up, or any other type of bike that uses dual coils?
Any input or ideas would be appreciated.
i_VTEC
Honda Motorcycles
23
Sep 5, 2014 04:16 PM
marcin b
Mar 5, 2014 05:57 AM
av_shadow700
Honda Motorcycles
Jun 7, 2011 08:25 PM
SlimBB4
Honda Motorcycles
Sep 5, 2007 10:15 AM
