94 Accord- ABS making strange noise
Old Oct 17, 2006 | 02:09 PM
accord_mike's Avatar
Default 94 Accord- ABS making strange noise
I'm hearing a strange buzzing noise coming from the brake fluid box which is located behing the driver's side headlight. IT buzzes about every 30 seconds or so after starting the car. Any pointers as to what is causing this?
Old Oct 17, 2006 | 03:50 PM
Ross 2.0's Avatar
In a Junkyard near you.
You probably need to replace the ABS unit. Tha accumulator has gone bad causing it to not be able to build up pressure.
Does it have fluid in it?
Old Oct 18, 2006 | 11:36 AM
Default Re: (Ross 4107)
Thanks for the reply...yes it does have fluid it it.
How hard is it to change?
Old Oct 18, 2006 | 11:40 AM
Ross 2.0's Avatar
not so hard as expensive. It's well over $1,000 just in parts for a new one. If you buy used you run the risk of the same problem
92JDMGSR
Suspension & Brakes
Mar 10, 2009 12:08 PM
vxnine
Jul 12, 2006 11:28 AM
Mike1486
Jan 17, 2005 01:20 PM
mr devious illusions
Aug 7, 2004 11:09 PM
