HELP! OBD-0 to OBD1, Mini-Me, Dpfi to Mpfi
UPDATED!
the car is starting!!!! but no power is getting to the wheels. it won't move? i don't know why? it passes 1500rpm and then drops back down when i'm trying to move it! HELP!
Modified by nickeynick at 7:48 PM 10/26/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">no, fuel into the chamber</TD></TR></TABLE>
you need to make sure your injectors are pulsing.
what info did you use for your mpfi, did you use obd1 injectors, and did you remove your resistor box?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">disconnect your dist plugs and try and start the car, then pull each spark plug and smell for fuel</TD></TR></TABLE>
i sniffed the spugs already when i turned over the crank to set to TDC. the injectors are shooting fuel so it's not that and i have an inline spark tester so i know it's not a problem with spark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink »</TD></TR><TR><TD CLASS="quote">you need to make sure your injectors are pulsing.
what info did you use for your mpfi, did you use obd1 injectors, and did you remove your resistor box?</TD></TR></TABLE>
Yah i'm using D16Z6 injectors...
For the MPFI i used these....
http://www.angelfire.com/d20/h....html
http://effinmotorworks.com/Effin_MPFI_swap.htm
theres only so much it could be
spark? also is it firing in the right order
fuel? also is it firing in the right order
timing? double check your timing by setting the cam and crank and see if its aligned then pull the dist cap and see if the rotor is pointing to number 1 wire
compression, do a compression check
thanks for all the ideas...i'm going to do another check of everything tomorrow! i'll let you know what happens!
One of the ecu pins was loose...b17 i think (igniter)...i puched it in and now the car is starting and staying on for one second then it dies...?
iat should be a red/yel and green/wht wire, make sure you didnt swap it with the eacv... should start either way, but still
still won't start. i'm taking a day off from the project maybe i'll be refreshed enough to find the problem on sunday.
alright i couldn't stay away from the car...i re-wired all the fuel injectors and the dizzy...finally wired my vtec...still won't start....i don't have the 4-wire oxygen sensor hooked up yet...could that be a problem?
Not that I think you are an idiot but you did use an OBD1 distributor right? Just checking because I have come across some people who have that before not knowing that they are different from OBD0 to OBD1...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 »</TD></TR><TR><TD CLASS="quote">Not that I think you are an idiot but you did use an OBD1 distributor right? Just checking because I have come across some people who have that before not knowing that they are different from OBD0 to OBD1...</TD></TR></TABLE>
yupp Brand New TD-42U distributor! no idiot here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote"> D.I.Y. / FAQ - OBD-0 --> OBD-1 Pinouts and Conversion Help
https://honda-tech.com/zero...age=1</TD></TR></TABLE>
thanks for that link i'm going to check out my pins tomorrow even though i think they're all right. i made my own OBD-0 to OBD-1 conversion harness so i was kind of iffy about my work but i've gone over the pins about 10 times but i'll double check.
i have the a mechanic friend of mine coming over to have a look at what i've done. i hope he finds the problem! *crossing my fingers*
