V-tec Not sounding like it should
Can heat soak effect how loud v-tec cracks? My S2K use to crack so loud when i first put my toda header, test pipe, and Apexi n1 on with the stock airbox, but after awhile it wasnt cracking half as loud as it was. I had a ARC airbox and chamber on there for 2 minutes then i took it off you guys are right that thing does suck. My engine bay gets so hot cause of the header i just wanted to know what your guys thoughts were on this. If any of you want that ARC set up ill sell it for cheap?
