d15 block, d-series cable transmission, SOHC valve cover, rear drum setup etc.
Old Oct 17, 2006 | 11:13 AM
EJ1 wilcox's Avatar
Default d15 block, d-series cable transmission, SOHC valve cover, rear drum setup etc.
I'm just trying to clear some stuff out of my garage and make a few bucks to go towards my turbo build.
1. First is a d15b2 short block that I pulled out of my 1990 Civic. The car had 90k miles on it when the engine was pulled. This block is dirty, but it turns over smoothly and without binding at all. The cylinder walls also look great. This block has a lot of life left in it!!
$60 OBO
2. This is the 4 speed manual transmission from the same car. Like the motor it has 90k miles on it. It still shifts smooth and has no grinds or leaks. It's ready to go!
$60 OBO
3. Rear drum brake setup for 88-91 Civics. Comes complete with the trailing arms, drum assemblys, and e-brake cables. I just don't need these anymore since I upgraded to disk brakes.
$30 OBO
4. SOHC valve cover. Was removed from the d15b2 engine above. I don't know what other SOHC engines it will fit, but I assume it would fit any of the SOHC engines from 88-91, and maybe some newer ones as well.
$20 OBO
Old Oct 18, 2006 | 09:47 AM
EJ1 wilcox's Avatar
Default Re: d15 block, d-series cable transmission, SOHC valve cover, rear drum setup etc. (EJ1 wilcox)
Bump!
Old Oct 20, 2006 | 08:15 AM
EJ1 wilcox's Avatar
Old Oct 23, 2006 | 06:54 AM
EJ1 wilcox's Avatar
Bump for flakers!
97civicswapped
K Series
Jan 16, 2014 05:34 PM
jaykerp92eg6
Northeast (Sales)
Nov 6, 2010 01:53 PM
BiG Chris
Northern California (Sales)
19
Apr 7, 2008 01:38 PM
Jap_Spec_Imports
Mar 26, 2008 05:02 AM
JRciv
Mar 7, 2005 07:53 PM
