Aluminum Radiator
Old Oct 17, 2006 | 09:51 AM
randY49's Avatar
Default Aluminum Radiator
Hey everyone,
I was wondering if anyone could tell me the differences between the stock radiator and an aluminum one? I assume that the aluminum would be lighter and more efficient.
That being said, would there be a point to putting one in a car (CRX) that is only going to be driven daily and occasionally at the track?
I spent some time researching the subject on honda-tech, but didn't find what I was looking for.
Thanks for helping out a noob.
Old Oct 17, 2006 | 10:47 AM
inspyral's Avatar
Aluminum radiators are usually thicker and have welded aluminum endtanks. The thicker core and welded endtanks are the primary advantages over a stock radiator. The thicker core give you more cooling capacity, and the welded endtanks aren't prone to failing like the plastic endtanks on stock radiators.
Old Oct 17, 2006 | 02:35 PM
dmotoguy's Avatar
Default Re: (inspyral)
plastic endtanks?? huh?
Old Oct 17, 2006 | 03:00 PM
randY49's Avatar
Thank you for the info, would there be any weight advantage or would it actually weigh more because it is thicker?
Old Oct 17, 2006 | 04:14 PM
inspyral's Avatar
Default Re: (dmoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmoto &raquo;</TD></TR><TR><TD CLASS="quote">plastic endtanks?? huh?
Go out and look at your stock radiator. The endtanks are likely plastic and bonded to the core with crimps or adhesive. If you don't know what an endtank is, it's the cap on either side of the radiator core(the core is the part with the fins that exchanges heat from the coolant to the air moving thru the radiator) where the inlet and outlet are located. If you don't know what plastic is, it's a chemically derived polymer material, commonly used for a variety of functions.
Old Oct 17, 2006 | 04:27 PM
dmotoguy's Avatar
hey man.. i never noticed they were plastic.. my bad.
Old Oct 18, 2006 | 10:10 AM
d16dcoe45's Avatar
Default Re: (dmoto)
copper/brass is actually a better conductor than aluminum--the aluminum radiator ususally make the car run cooler because they are thicker and there are simply more fins/surface area to dissipate heat.
b16a4
Sep 5, 2007 05:14 PM
eecc
Acura TL, RL & ZDX
May 14, 2005 03:29 AM
mrlegoman
Welding / Fabrication
Jan 4, 2005 05:39 AM
Mike813
May 27, 2003 06:07 AM
