FS-85 Corolla GTS Hatch AE86 (WI)
Old Oct 17, 2006 | 08:33 AM
Funkmaster Ferio's Avatar
Default FS-85 Corolla GTS Hatch AE86 (WI)
I picked this GTS up locally at a little mom and pops dealership that was just going to auction it off cause of age being they don't sell thing that old. When I got it, it needed some loving such as it needed a new alternator, rear calipers and other little odds and ends. I am the 3rd owner and the second owner was a woman who owned it since 87 and have the window sticker and paperwork to prove it. My wife and I decided to have a child so I want something with alittle more room and 4dr's.
lowdown
-Engine/Drivetrain
-HKS intake
-TRD header(header wrap just installed and coated with DEI silicone header wrap spray)
-New Alternator
-new clutch slave cylinder
-steel braid clutch line
-Sprung 6 puck clutch
-TRD 2 way LSD(lsd and 3rd member setup by Toysport)(kouki version and not zenki even though the car is a 85)
-Kouki axles(rear have ARP ext studs and just haven't gotten around to installing the front studs yet but I have them)
-Techno Toy Tuning shifter bushing kit
Susp/brakes
-tokico blue shocks (front and rear)
-Espelir ASD springs (front and rear)
-Spats front strut bar
-custom rear carbon fiber strut bar
-4 link(only uppers installed yet but have lower links also)
-adj lateral rod
-new rear calipers
-new front and rear rotors
-Axxis Metal Master pads front and rear
-5pc steel braided brake lines
Body..etc..
-Painted 03 Saturn Vue Orange
-New fender flares(not installed yet)
-FX16 side skirts
-new kenwood speakers front and rear
-JDM August Feroce 3 pc rims 14x7 front 14x7.5 rear(purchased from Takumi Project)
-Sumitomo HTR tires
-older Bride Brix seat(gradiation)
-custom side exit exhaust..thrush glasspack and two OEM Harley softtail slashcut pipes(umm can you said loud!) Still stock crushpipe exhaust also
-Sweet 3 spoke wood rim steering wheel(have original wheel also)
The bad
-being it was a midwest car it's whole life it's has rust. Pretty much all of it I fixed but the I bought the fender flares so all rust that is on the car(basically all on the lips of the wheelwells)would be cut off to install the flares. I just didn't install the flares yet since I wanted some wheel spacers before hand since it would look goofy without them as the wheels don't have that much offset. Some of it is peeking through on the front driverside fender.
-Cluster doesn't light up(bad headlight switch/rheostat) they were working when I bought the car but then it started to go out and no just doens't come on. All it needs is just a new switch...cheap fix headlight work fine though as does the cluster but just doens't lightup.
-front driver side wheelbearing is going but I have new one and just have to install them.
-Rear passenger side rotor I believe is slightly warped and howls on light braking. If you step on it with more pressure it doesn't make a sound. It works fine but sometime is just irritating. They were just stock replacements from a local carparts place.
-No e-brake since they were severely corraded when I got the car and first time pulled on it they snapped and then the original calipers froze so thats why it has new rear calipers. I just never got around to buying a new e-brake cable.
The good
-ICE COLD AC and work perfectly! Oh and has working power steering too.
-Still has the stock original bluetop 4age that runs perfectly
-No sunroof
-full interior
-comes with stock pizza cutter wheels also []
-Runs like a top as it's my daily driver
Pics
day I first bought it
painted,wheels,susp
August feroces 14x7(F)14x7.5(r)
older battle style Bride Brix
$3500 will trade with some cash for a AE102 93-97 4dr 5spd Corolla in good condition
I'm in Neenah WI which is about an hour north of Milwaukee/Madison and 30 minutes south of Green Bay.
I also have a complete 20V silvertop that I was going to install that I include for extra. Has everything needed for a stock running swap(ECU, complete harness, ignitor,coil) Take it all for $4000. Email for more info or other ?'s.
Hndphilemon@tds.net
AIM- Dr Dee Struct0
Will to trade also for a clean 5spd 4dr EK(96-00)(EX or LX no DX's)
Old Oct 27, 2006 | 07:22 AM
Default Re: FS-85 Corolla GTS Hatch AE86 (Funkmaster Ferio)
TTT
Eg_Hatch92
Transmission & Drivetrain
Dec 11, 2014 09:43 PM
dRuNkEnMoNkEy97
Sep 26, 2007 06:08 AM
Funkmaster Ferio
Oct 27, 2006 07:19 AM
civic_driver
Nov 2, 2005 09:45 AM
