H22A5 in a 4gen Prelude 2.3si
Got a H22A5 engine very cheap and since my H23a2 engine is pretty much dead, I want to swap the h22a5 to my Prelude. After reading a bit on the net regarding engineswaps, I've understood that this should be possible. I've also figured out that I need to get a ODBII ECU, or would a P13 ODBI ECU work together with the H22a5 ? Since the ODB II ECU (P5M) probably has Immobilizer on it, ODBI ECU would be better for me? Or am I way out on the fields....?
Anybody who can help me choose the right ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowBB4 »</TD></TR><TR><TD CLASS="quote">what did the h22a5 come in and the h23a2???????????</TD></TR></TABLE>
European model.
European model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">Get an OBDI P13.
You'll also need the OBDI H22 injectors and reuse the distributor from the H23.</TD></TR></TABLE>
Well..having some trouble finding H22 injectors.. could I use the H23 injectors temporary while I'm searching for H22 injectors..? Will it do any damage using them for a while?
By the way.. I'm european...from Norway.
H22a5 = 97+ euro 2.2 vtec Prelude
H23a2 = 92-96 euro 2.3 non-vtec Prelude
you really should not use the h23s with an obd1 p13. the ecu is mapped for a 345cc injector and the h23s i believe are less then 300 I cant remember off the top of my head.
the car will run lean with the h23s. which is unsafe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon »</TD></TR><TR><TD CLASS="quote">you really should not use the h23s with an obd1 p13. the ecu is mapped for a 345cc injector and the h23s i believe are less then 300 I cant remember off the top of my head.
the car will run lean with the h23s. which is unsafe.</TD></TR></TABLE>
agreed. if anything run it on the h23 ecu with h23 injectors and go without vtec for awhile. still not 100% ideal, but should get you in the ballpark.
i am running a obd II h22 in my 94 si and made it obd I but did not change injectors.
OBD I H23A= 245cc
OBD I H22a= 345cc
OBD II h22a= 295cc (which is what i have even tho i am obd I now)
They are great and i see no difference. leaner is faster but will burn a hole in the piston if too lean. But i think it isnt much leaner than it would regularly be because i have a cel for code 12 (egr inssuficent lift detected)
OBD I H23A= 245cc
OBD I H22a= 345cc
