help!!! please wiring
I have searched everywhere, but i still can't find the wiring diagram for a 95 integra gsr gauge cluster. I'm putting one in my 89 si. Any help is greatly appreciated.
STRAIT OUT OF THE FAQ
THIS IS FOR THE 90-91 BUT DOES HAVE PINOUTS FOR THE GSR CLUSTER SO USE THEM AND GET YOUR OWN 89 PINOUTS.
Here are the 94-99 Integra and 90-91 Crx guage cluster pinouts and how I put them together.
Ok so after spending some days on this little project and searching the web for some pinouts I just opened a Service Manual and found the pinouts myself, you should do this too if you are confused with my write up.
The way i labeled them is from the Wire side of the plug.
94-99 Integra Gauge Cluster Pinouts ---------------------------
A.
1. Seat Belt ----- (red/blue)
2.
3. Fuel Gauge ------- (yellow/white)
4.
5.
6. Vss ---- (orange) *will need to add
7. Trunk ---- (Green)
8.
9. Dash Brightness --- (Red)
10. Gauge Lights -- (red/black)
11. 12v Power --- (Black/Yellow) *can be used for VSS power
12.
13. Left Turn signal --- (Green/Blue)
14. Right Turn Signal -- (Green/Yellow)
15. High Beam --- (Red/Green)
16. E-Brake Light -- (Green/Red)
B
1.
2.
3.
4. 12v Power --- (Yellow)
5.
6. Ground ---- (Black)
7. Coolant Temp -- (Yellow/Green)
8.
9. Battery Light/Alternator -- (White/Blue)
10.
11. Oil Pressure ---- (Yellow/Red)
12. Check Engine Light -- (Green/Orange)
13. Tachometer --- (Blue)
90-91 CRX gauge cluster pinouts -------------------------------
C.
1. Left Turn ---- (Green/Blue)
2. High Beam ---- (Red/Blue)
3. Coolant Temp -- (yellow/Green)
4. Dash Brightness ----- (Red)
5. Gauge Lights ----- (Red/Black)
6.
7. E-Brake ---- (Green/Red)
8. Oil Pressure --- (yellow/red)
9. Check Engine Light ---- (Green/Orange)
10. 12v Power ---- (Black/Yellow)
11. Battery/Alternator Light ---- (White/Blue)
12. Tachometer --- (Blue)
D.
1. Ground ---- (Black)
2.
3.
4. Trunk ---- (Green/Black)
5. Seat Belt ---- (Blue/Red or Blue/yellow)
6. Fuel Gauge --- (Yellow/White)
7. 12v Power ---- (Yellow)
8. Right Turn --- (Green/Yellow)
90-91 Crx pinouts ---------------- 94-99 Integra Pins added
C
1. L Turn ---- A13
2. Hi Beam --- A15
3. Coolant Temp --- B7
4. Dash Brightness --- A9
5. Guage Lights --- A10
6.
7. E-Brake --- A16
8. Oil Pres --- B11
9. CEL --- B12
10. 12v Power --- A11
11. Battery/Alternator -- B9
12. Tachometer --- B13
D
1. Ground --- B6
2.
3.
4. Trunk ---- A7
5. Seat Belt --- A1
6. Fuel Guage ---- A3
7. 12v Power --- B4
8. Right Turn --- A14
Also, the Dimmer does not work. It stays on a constant brightness. I am working this bug out I think you have to bypass your Brightness control unit (which on the integra it is internal at the controller)
Thanks for looking,
Shane
A.
2.
4.
5.
8.
12.
B
1.
2.
3.
5.
8.
10.
C.
6.
D.
2.
3.
C
1. L Turn ---- A13
2. Hi Beam --- A15
6.
7. E-Brake --- A16
8. Oil Pres --- B11
9. CEL --- B12
D
1. Ground --- B6
2.
3.
4. Trunk ---- A7
5. Seat Belt --- A1
7. 12v Power --- B4
Thanks for looking,
Shane
tilhasbb
Jan 26, 2009 10:39 AM
vtecn8ive
27
Nov 4, 2007 05:41 AM
Driven
Feb 14, 2002 02:59 PM
