High rev problem??
When I rev to like 5000 in first to third the motor seems to bog and then pick up after that?? I have a b18c and running a pr4, any one have anyideas, I put high octane gas in and fuel injector cleaner. Still does it though, I'm stumpped??
2. the ecu has no VTEC
3. your GSR secondaries arent opening
4. the pr4 fuel maps are *** for the gsr motor..
GET A GSR ECU.!!!
Isn't that normal for a car to do that? If you were at 5000 in 1st and shifted to second it would be probably a little over 2000 or something, and since Hondas have no torque it is going to go quite slow at that. So the solution is to not skip 2nd gear!
Turbogsr2000
Jul 27, 2009 08:16 PM
