Motherf**king Motor Mounts
Old Oct 16, 2006 | 10:28 PM
Spoolind16's Avatar
Default Motherf**king Motor Mounts
Ok I am pissed about all the bad and misinformatin on HT about b18 swaps in 92-95 civics. I have a b18a1 out of an 92 LS Integra. I would like to know exactly which mounts and brackets I will need for the swap. I have a 95 4dr Civic currently with a d16z6 in it. I would like to replace the d16z6 with the b18a1. I've heard so many conflictin views and suggestins through all the searchin on this site I'd like some real answers.
PS: I would like to have the engine fit in straight with no binding on either the axles or engine mounts!!!!!!!!!!!!!
Old Oct 17, 2006 | 08:09 PM
silverEG6's Avatar
heres what i have learned for every swap i have done for the EG models use the intega motor mounts.. rear motor bracket and all down to the torque mounts and the years you can use are from 94-01 any thing 93 and below you cannot use.
and plus if your using a B18a1 that swap has a cable tranny.. you can either find a hydro tranny or get a hasport cable to hydro conversion kit.. i think it would be a waste of money to convert it.. but thats just my personal outlook... hope that helps
Old Oct 18, 2006 | 05:43 AM
YZFR6's Avatar
Default Re: Motherf**king Motor Mounts (Spoolind16)
You could use most of your factory mounts, but your going to need a Cable/Hyd. conversion mount kit just on the tranny side. Hope that helps.
Old Oct 18, 2006 | 08:31 PM
Spoolind16's Avatar
Default Re: Motherf**king Motor Mounts (YZFR6AVID)
or just a hydro tranny which is what I'm going to do
95teilhatch
May 17, 2007 06:08 PM
NSfit
Sep 15, 2006 10:37 AM
HiProfile
Sep 2, 2005 10:01 PM
Gimpo
May 11, 2004 10:50 PM
d!zZy
Jan 30, 2003 04:35 PM
