Suggestions on more power/tourque from the SOHC crowd!!! Help a fellow sohc owner.
Old Oct 16, 2006 | 08:23 PM
Xemu's Avatar
Default Suggestions on more power/tourque from the SOHC crowd!!! Help a fellow sohc owner.
This is my set up.CRX Si with D16Z6 and Si transmission.I have a comp cam 59100,cai,header and stainless exhaust.What I'm wondering is where to go to next in order to squeeze more power out of my set up.I don't want turbo or supercharger.I want to keep it all motor.
Will a lightened flywheel and new internals in the block help out?? If so what do you suggest?? Also what can be done to the tranny as far as gearing is concerned?? I'm fairly new to the Honda scene but hooked and here to stay.So I'm open to any and all suggestions as I'm far from a master mechanic.Thanks guys.
I hear Eagle makes good product so maybe some pistons/maybe not,gimme some sugestions!!
Old Oct 16, 2006 | 08:29 PM
crxnj's Avatar
Default Re: Suggestions on more power/tourque from the SOHC crowd!!! Help a fellow sohc owner. (Xemu)
all motor sohc with power while still running on pump gas is a hard one..How much actuall power are you trying to make? what sort of 1/4 mile times are you looking for? and what is your budget?
a lightened flywheel doesnt really give more power,maybe 1whp? but the revs go up and down faster..
Old Oct 16, 2006 | 08:37 PM
Xemu's Avatar
Default Re: Suggestions on more power/tourque from the SOHC crowd!!! Help a fellow sohc owner. (Mr.speaker)
I'm not looking for 200 horses but 170 would be nice.Would swapping out the internals in my block help?? What about tranny gearing anything I can do there??
Old Oct 16, 2006 | 08:43 PM
crxnj's Avatar
check this for the tranny http://effinmotorworks.com/Eff...s.htm
170whp all motor is going to be tough..I mean its been done but i doubt it's streetable and its going to be alot of money.. Just curious why don't you want turbo? cause you can eaisly have a turbo kit,tuning,and make +200whp with around $1000-$1500
Old Oct 16, 2006 | 08:45 PM
Redline130's Avatar
170 all motor from a SOHC is a challenge. Is there any reason for not wanting to go with forced induction? You will most definitely need higher compression pistons to see some sort of significant gain.
Old Oct 16, 2006 | 08:59 PM
Xemu's Avatar
Default Re: Suggestions on more power/tourque from the SOHC crowd!!! Help a fellow sohc owner. (Redline130)
I've never really dealy with turbo.I think it just kills your engine faster than if it was kept natually aspirated.I just think so many things can go wrong with a turbo set up.
Old Oct 16, 2006 | 09:19 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote">I've never really dealy with turbo.I think it just kills your engine faster than if it was kept natually aspirated.I just think so many things can go wrong with a turbo set up.</TD></TR></TABLE>
If done right, a turbocharged motor can last just as long, if not longer than a high compression naturally aspirated set up. Besides nitrous, boost is the best bang for the buck. You should look into to dispell whatever rumors or myths you may have about turbocharging. In this day and age, turbocharging can be done very easily and inexpensively.
Old Oct 16, 2006 | 09:32 PM
Xemu's Avatar
What are some things I should look for in a turbo set up then?? Are the cheap ones on ebay good?? Should I lean towards putting money into the actual turbo or piping?? Gimme some starters and maybe I might go turbo.This is a great site!!!
Old Oct 16, 2006 | 10:14 PM
crxnj's Avatar
read this http://www.homemadeturbo.com/f...135.0
Old Oct 16, 2006 | 11:48 PM
Xemu's Avatar
Great info?? But is there anything I should be worried about with a turbo?? My motor has 59,000 miles so mileage is ok.But will my tranny take it,is there any preventive maintenance I can do?????
Old Oct 16, 2006 | 11:50 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote">Great info?? But is there anything I should be worried about with a turbo?? My motor has 59,000 miles so mileage is ok.But will my tranny take it,is there any preventive maintenance I can do?????</TD></TR></TABLE>
you may want to upgrade the clutch,,Get a stage1 for around 200whp..there's nothing you have to worry about the engine and tranny can handle turbo no problem just make sure its tuned good.
Old Oct 17, 2006 | 12:07 AM
Xemu's Avatar
If I do decide to go Turbo after everything is hooked up I will definately take it somewhere reputable to be tuned.
Old Oct 17, 2006 | 12:19 AM
crxnj's Avatar
^ There's a place about an 1 hour away from you in hempstead,, called trick engineering give him a call 603 329 6083 i hear they give discounts for honda-tech members
Old Oct 17, 2006 | 12:41 AM
Xemu's Avatar
I heard there is a place in Concord too called "TDC Tuning" they come highly recommended also.But If that place is used to dealing with Honda's I'll give em' a try. Where are you located??
Old Oct 17, 2006 | 12:50 AM
crxnj's Avatar
I'm in NJ.. i dont think that he is honda specific but the guys does good work,i met a couple guys at raceway park with different cars, hondas,nissans,v8's...Im not sure exactly what he can tune but i know the guy is certified hondata and aem tuner..
Old Oct 17, 2006 | 12:53 AM
crxnj's Avatar
also you can check their website http://www.trickengineering.com/
maxwellsohc
Jun 29, 2008 08:05 PM
leebo
Honda Fit
Apr 15, 2007 06:52 PM
extrmeboost
Nov 10, 2005 02:15 PM
SooN_2_B_SiR
Jul 9, 2004 07:02 PM
Drew Peacock
Jan 24, 2003 07:52 PM
