HAVING A PROBLEM WITH MY CRX NEED HELP WONT START
HEY HONDA-TECH IM HAVING A WORRIED PROBLEM WITH MY CRX. IT WONT START UP FOR NOTHING. THE WORRIED THING ABOUT IT IS THAT THE STARTER WONT SPINE IT DOESNT DO ANYTHING ONCE YOU TRY TO TURN IT ON. I NO ITS THE NOT THE STARTER BECAUSE I TOOK IT TO AUTO ZONE AND THEY TEST IT OUT AND IT IS GOOD WORKING CONDITION. SO I NO ITS NOT THE STARTER WHAT DO YOU THINK IT IS? IT SOUNDS DEAD IT DOES NOTHING WHEN I HIT THE KEY SWITCH TO TURN IT ON. THE STARTER DOESNT GO OFF OR NOTHING. ITS A TRIP I MEAN IT WAS RUNNING WELL ALL OF A SUDDEN THE NEXT DAY IT DIDNT TURN ON. THIS A WORRIED PROBLEM ALSO I TRY TO TURN ON THE CAR BY TUCHING NEGETIVE AND POSTIVE WITH A SCREWDRIVER ON THE STARTER AND STILL NOTHING ITS DEAD. THE STARTER THOSENT TURN THE FLYWHEEL WERRIED.!!!!! CAN ANYONE HELP WITH THE PROBLEM I REALLY NEED TO GET IT GOING BEFORE TRACK DAY IN SACRAMENTO OCT.29.
Check your ground if your battery is property charged, maybe fuse? idont know if there are fuses for the started like the alternator, but maybe check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxben »</TD></TR><TR><TD CLASS="quote">Is the battery dead? </TD></TR></TABLE>
so no crank or anything..???
did it shoot out and spun when
u tested it at autozone?
do u have ur signal connect also on ur starter?
also try push starting ur car to make
sure it didnt seize...
yes it did shout out and spun at the auto zone. but just wanted to let you guys know that i fixed the problem today. it was the wire for the starter you know the one that carries the positive was not getting enough current from my fuse box so i just ran it straight to the battery which i have relocated in the rear of the crx. thanks for all you guys tryin to help me out all those things you guys said i had already check them out. anyway thanks honda-tech see you at the track ocotber 29 at sacramento ill be in my white crx with gsr motor lsd tranny. watch out.
there is a starter solenoid under the dashboard, change it. When it happen to me it would just click and not crank at all. I went crazy trying to find out what it was. I finnally gave in and took it to my mechanic, told me he changed this:
junya16
Feb 26, 2003 08:31 AM
elpermgrande
Aug 9, 2002 06:43 AM
