Have you prepped your car for the EXPO.?
Old May 4, 2002 | 07:09 AM
Dropspeed's Avatar
Default Have you prepped your car for the EXPO.?
In the last week I have,
Removed both airbags, all of the wiring, the control unit, extra bracing and installed my Sparco wheel
Removed intake manifold, had it angle milled, and reinstalled with Hondata gasket.
Turned stock rotors so they are ready for the Hawk Blues again.
I'm heading to the dyno in a couple of hours for some runs.
Still need to have ID stickers made for the window, and order a fresh set of hoosier.
I don't usually have this much time, but I don't start my new job for about 2 weeks.
Mattj
[Modified by Dropspeed, 11:10 AM 5/4/2002]
Old May 4, 2002 | 07:14 AM
yoshi234's Avatar
I shoot brides
Default Re: Have you prepped your car for the EXPO.? (Dropspeed)
prep'n fo da Expo = phun
yshi - hu wundaz wut matt's nex j0by j0b is
Old May 4, 2002 | 07:24 AM
sackdz's Avatar
Default Re: Have you prepped your car for the EXPO.? (yoshi234)
Installed jdm fd
Installed new 3-4 synchros
Installed Spoon flywheel
Installed Tein HA's
Installed SS brake lines
Got lugs for Race Rotas and Matt's used rubbr. (stikki kuhmos)
Got P+ Fronts for track
I'm almoist ready, need an alignment and a car wash
Old May 4, 2002 | 07:25 AM
hybridkid's Avatar
i'm all set, my car has gas and i got my camera to take pics, its not like i ever race my car
Old May 4, 2002 | 07:29 AM
kitkatR's Avatar
Default Re: Have you prepped your car for the EXPO.? (hybridkid)
I bought a helmet
Old May 4, 2002 | 07:34 AM
Dropspeed's Avatar
Default Re: Have you prepped your car for the EXPO.? (kitkatR)
I bought a helmet
Speaking of, does anyone know the requirements for helmets, S95, m95 and above????
I mights need to add that to my list.
Mattj
Old May 4, 2002 | 08:12 AM
sackdz's Avatar
I bought a helmet
Mattj
From CGI website:
Q. Do I need a safety helmet?
A. Yes a Snell 95 or 2000 approved helmet is required.
Old May 4, 2002 | 08:17 AM
uNF$@#!'s Avatar
Default Re: Have you prepped your car for the EXPO.? (sackdz)
Brett and I will be hosting a group buy on several Bell helmets very soon. (within the week)
I will keep you all posted. No official word on pricing yet, except expect better pricings if we get 20 or more helmets sold! (I am not making 1 dime off of this btw)
Old May 4, 2002 | 08:59 AM
Mike M's Avatar
Founding Member
Default Re: Have you prepped your car for the EXPO.? (00-0187)
I'd say buying a helmet without trying it on is a bad Idea, Unless you were to already have the same helmet and size to try on from a friend or if you went to a store and tried on said helmet.
Old May 4, 2002 | 09:08 AM
Mike M's Avatar
Founding Member
Change oil and filter, Flush Brake Fluid, Check pads and bring and extra set and good to go
Old May 8, 2002 | 04:27 AM
Willard's Avatar
Have you prepped your car for the EXPO?
My car is ready at all times...
You never know when you may need to drive on the track.
Panther+ pads on the rear.
PantherXP pads on the front.
ATE super Blue in the brake lines.
Mobil 1 in the engine.
I may try and get a 'track' muffler constructed before the expo... and install another intake.
Will
-who will be loading the car on the trailer on the 23rd...
Old May 8, 2002 | 04:52 AM
BudMan's Avatar
Default Re: Have you prepped your car for the EXPO.? (Willard)
I just want to see who I can outrun with a full interior - NO weight reduction (Including my extra 40lbs **fatass**) & street tires
Long live my 86,000 mile daily driver - whooooohoooooo
Oh yea - I wanna start a job in 2 weeks
[Modified by BudMan, 7:52 AM 5/8/2002]
Old May 8, 2002 | 05:02 AM
Willard's Avatar
Default Re: Have you prepped your car for the EXPO.? (BudMan)
street tires + stock interior ITR + 240lb driver = happy time.
new jobzor = W00T!
Will
Old May 8, 2002 | 05:03 AM
Back in Black's Avatar
Rather OG
Nope, not even close
I've yet to:
Install FD/Clutch/Flywheel
Install new front pads and rotors
Change tranny fluid
Change oil
Change coolant
Reinstall 6-point cage
Install Seat
Install 5-point harnesses
Jason-
who will be very busy this weekend
Old May 8, 2002 | 05:37 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Have you prepped your car for the EXPO.? (Vader in NC)
I've been prepping my liver
Pat, who has been busy wrenching on his R, but for a different reason
Old May 8, 2002 | 05:42 AM
davidnyc's Avatar
Default Re: Have you prepped your car for the EXPO.? (itr009)
changed tranny fluid
changed engine oil (mobil 1 5w-30, will be bringing extra quarts just in case)
changing brake fluid this Sunday (ATE Superblue)
Azensis on car (may bring R-compound also, but doubt it)
need to buy camera mount ( Anyone selling a harness bar ??? )
need to make arrangements with other drivers for caravan
Old May 8, 2002 | 05:44 AM
Rather OG
Default Re: Have you prepped your car for the EXPO.? (davidnyc)
It would be nice to caravan, although I'll be leaving to early for the local f00ls
Jason-
who plans to depart Greensboro, NC no later than 4am
Old May 8, 2002 | 05:50 AM
nsxtcjr's Avatar
New User
Well... I changed fluids a few weeks ago. But since then I did BMW CCA track events at Putnam Park and at Road America, so I'm not sure that counts.
I'm gonna swap pads, but I'm not sure that counts, either, since I'm doing another BMW CCA event at Mid-Ohio immediately before the Expo.
Oh, and I bought a couple more track tires, so I can bring an extra one with me to Mid-O and the Expo, since one of mine is pretty worn.
It would be nice to caravan, although I'm not sure what time I'll be able to leave Mid-Ohio for the Expo. Depends how long my students stick around on Sunday.
Old May 8, 2002 | 05:53 AM
Ausmith's Avatar
No I'm not ready at all. I have a list longer than this thread of things I should really do.... but I'm pretty broke from my hatchback project... Things I will do before expo:
Change timing belt
New cap, rotor, wires, plugs
Adjust valves
Change tranny fluid
Flush/bleed brake fluid
Turn rotors
Buy new pads
Buy new rotors
Change oil
Track alignment
Install stock front sway bar
Get slicks mounted
Wash/wax
The Mugen R is running like poopy lately - well ever since I took it to Florida/Atlanta and got bad gas from Potter Spurlock in the NC mountians which cuased some knocky knock at 18degrees. Well she still made 179whp at 16degrees... but it feels like a turd compared to the hatch. Anyway I gots a lot to do.
Clayton - who wishes he didn't have a job for the next two weeks and $5k cash money
Old May 8, 2002 | 07:03 AM
ZygSpeed's Avatar
Default Re: Have you prepped your car for the EXPO.? (Ausmith)
I think I'm screwed!
Probably need FR wheelbearing.
I'll be checking/prepping the car this weekend in Youngstown (at my Mom's).
Ain't I a great kid to visit my dear old Mom, on Mother's Day!
Old May 8, 2002 | 07:06 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Have you prepped your car for the EXPO.? (Zygspeed)
well since I decided not to spend money on my 93Beater, I guess I'm ready. Do need to fix the P/S system cause it leaks, get a helmet (or more likely, borrow one) and mount some street tires on the beater.. oh and buy a truck.. and prep the trailer.. fuxor.
Old May 8, 2002 | 07:08 AM
AssPenny's Avatar
Default Re: Have you prepped your car for the EXPO.? (b00st-0wnz)
We are a bunch of slackers....
I still need
- Truck
- Trailer
- rotors
- mount tires on rims
- get helmet
- get new glasses/contacts
Old May 8, 2002 | 07:11 AM
Ausmith's Avatar
I think I have a full ITR upright w/ bearing and hub sitting in my garage. Let me know if you want me to bring it.
Clayton -> who figures that throwing more junk in the car can't hurt at this point
Old May 8, 2002 | 07:18 AM
Willard's Avatar
Default Re: Have you prepped your car for the EXPO.? (AssPenny)
Truck = U-haul?
Trailer = done?
rotors = Autozone ('95 Acura Legend 4 door sedan Le/SE model)
mount tires on rims = $8 each ad BJ's whole sale club if you get to Charlotte in time.
get helmet = jegs/summit = easy job
get new glasses/contacts = coke bottles?
Old May 8, 2002 | 07:25 AM
ZygSpeed's Avatar
Thanks, I appreciate it.
I really should have checked it out before now, but I'm a lazy SOB with no garage!
I'll let you know after this weekend. thanks Ed
[Modified by Zygspeed, 11:26 AM 5/8/2002]
