Skunk2 Hi Compression Valves?
Old May 4, 2002 | 06:31 AM
Racebrewer's Avatar
Default Skunk2 Hi Compression Valves?
I noticed hat Skunk2 has High Compression Intake and Exhaust valves (plus .3 to.5 points).
Does anybody know anything about these valves and, especially, what are the downsides?
Thank you,
John
Old May 4, 2002 | 06:39 AM
Rob :190:'s Avatar
Default Re: Skunk2 Hi Compression Valves? (Racebrewer)
valves can change compression? someone please explain if possible.
[Modified by Brian Spilner 1035, 10:39 AM 5/4/2002]
Old May 4, 2002 | 06:42 AM
MackSpeed-616's Avatar
Default Re: Skunk2 Hi Compression Valves? (Brian Spilner 1035)
figure it out... the combustion chamber volume in relation to compression ratio
Old May 4, 2002 | 06:49 AM
Padawan's Avatar
Darth ModerVader
The only way I could imagine that working is if the valves have more material on the underside, thus reducing combustion chamber volume and increasing compression. I would also assume that this would add weight to the valves and could possibly interfere with the flow of cylinder gasses. IMO there are much better ways to increase compression.
Old May 4, 2002 | 07:28 AM
Zeus's Avatar
Default Re: Skunk2 Hi Compression Valves? (Spec.R 00-0123)
They are flat on bottom instead of dimpled(sp?)... as in the pic below linked from the Endyn site from a year ago or so...
Stock vs Endyn/Skunk/whoever else is selling them...
[Modified by Zeus, 10:32 AM 5/4/2002]
Old May 4, 2002 | 07:46 AM
Default Re: Skunk2 Hi Compression Valves? (Zeus)
yeah.. the high comp valves are for n/a i want some of the special turbo valves that build boost
Old May 4, 2002 | 09:14 AM
Mike M's Avatar
Founding Member
Default Re: Skunk2 Hi Compression Valves? (Mr. Bait-R 616)
Looks like SuperTech's valves, I'll be trying out a set soon.
h46it
Jun 2, 2002 09:36 PM
