F22b Motor Problem All help appreciated
Old Oct 16, 2006 | 04:32 PM
DMMF22B13's Avatar
Default F22b Motor Problem All help appreciated
Have a 95 honda accord its manual, did a motor swap same motor (2.2 v-tec sohc) but it was auto matic dropped it in after I hooked it up to my 5 speed, Have a cheek engine light with codes 1 and 14 followed up on those but no change
Used original wireing harness and stock ecu
Code one being a O2 sensor heater cir problem
Code 14 being an Idle control problem/idle air controle or valve cir failure
Alldata- Nodata told me trany codes would also refrence through the check engine
code 1 being Lock up clutch dosent disengage
code 14 trany shift hard when shifting
Actual conditions felt
stumbles in all gears up to about 2500rpm its slugish and stuttering
Shift hard but from there up acceleration is fine
out of gear you can rev it up just a lil and rpm jumps up and down
everything seems to be in order but cant put a finger on this problem
Also note that if I clear the codes the retern with out any drive cycle- hard codes
Any help would be great beeting my head off the wall over this one thnaks
DM13
Modified by DMMF22B13 at 8:40 PM 10/18/2006
Old Oct 16, 2006 | 06:36 PM
BlUAc's Avatar
Default Re: F22b Motor Problem All help appreciated (DMMF22B13)
is your d4 light on and did you check the small things like passing gear cable not connected or you left some silnoids unconnected dont no much bout auto trannys but thought i might put my two cents in
Old Oct 16, 2006 | 06:50 PM
stone_32's Avatar
Is the car AT or MT? What computer are you using? all stock I suppose. Did you use the engine harness from your motor or the new one?
Old Oct 16, 2006 | 09:07 PM
DMMF22B13's Avatar
its manal but the motor i got was hooked up to an automatic originaly and i was told that they used diff inj i didnt know if there where any other major diff if any in motor design sorry should have explained that better
Old Oct 16, 2006 | 09:08 PM
DMMF22B13's Avatar
computer stock for now and harnes from the original
DMMF22B13
Oct 19, 2006 08:25 PM
NJcivic21
Nov 9, 2005 11:44 AM
rtpassini
Jun 25, 2004 12:17 AM
mikeaagesen
Aug 24, 2003 12:40 PM
Fatty_1775
Jul 25, 2003 04:52 PM
