Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
upgrading .. okay before swap?
Old Oct 16, 2006 | 04:24 PM
em2_blk_01's Avatar
Default upgrading .. okay before swap?
okay i plan on performing a kswap on my 01 ex in about a year and half at the same time i'll also be changing the transmission from auto to manual. in the mean time what components can i upgrade that won't need to be changed ... i know rims i can ... also brakes and suspension what about strut bars are they according to the engine or car body chasis?
Old Oct 16, 2006 | 04:49 PM
Vantage's Avatar
you should be safe with a Neuspeed upper front, But rear upper/lower and upgrading the rear sway should be fine. I'd leave upgrading the exhaust alone, because a Kswap will require a large diameter exhaust than a dseries should use.
Old Oct 16, 2006 | 08:09 PM
bravo831's Avatar
Default Re: (B18a_CRX)
also sway bars, also if your into it maybe a carbon fiber hood and or trunk change the rear to discs, maybe seats,
Old Oct 18, 2006 | 07:26 PM
K20boiZ's Avatar
Default Re: upgrading .. okay before swap? (tanoli)
the best thing to do would be work on your suspension. get a good adjustable suspension setup or just some good shocks/springs if your into that. and rear discs helps out alot when you want to start going fast. dont touch the drivetrain or engine bay or you'd be wasting money.
jdmnic91
Apr 24, 2013 11:45 AM
DreamCatcher
May 18, 2005 03:35 PM
paulzy
Feb 2, 2003 06:49 PM
mackymcg
Jul 9, 2002 01:06 PM
