** ANYBODY USING THIS SX PERFORMANCE ELECTRIC FUEL PUMP AND FUEL REGULATOR **
Old Oct 16, 2006 | 02:50 PM
IT'S ME DAVID's Avatar
NooB
Default ** ANYBODY USING THIS SX PERFORMANCE ELECTRIC FUEL PUMP AND FUEL REGULATOR **
A friend of mine called me right now and said he as a new sx performance fuel pump for $250 and fuel regulator for $100.First question is has anyone used these products and is it better then getting an aeromotive setup.Ill be using a GT42R.Also can someone point me in the direction of any sites that has a price listin for these products.I tried to search on honda-tech but of course sx doesnt show up on the search.
http://force-efi.com/sx.htm
Make no mistake about it SX have achieved the only pump available to meet both high pressure/high volume and low pressure/high volume fuel system demands. We rate the pump as able to support up to 1000hp at 45psi.
The SX Performance series of fuel pressure regulators allow maximum tuning flexibility with absolute minimum flow restriction for engines up to and exceeding 1500hp. Our regulators advanced bypass technology and enlarged port design provides rock steady fuel pressure control from idle to full throttle, and allows our pump to push more fuel, increase horsepower, run cooler, draw less current. All this with absolutely no pressure creep!
Old Oct 16, 2006 | 03:07 PM
Boner_Ben's Avatar
Default Re: ** ANYBODY USING THIS SX PERFORMANCE ELECTRIC FUEL PUMP AND FUEL REGULATOR ** (IT'S ME DAVID)
I have the sx regulator, its exactly the same as the aeromotive.
Old Oct 16, 2006 | 03:50 PM
NooB
Default Re: ** ANYBODY USING THIS SX PERFORMANCE ELECTRIC FUEL PUMP AND FUEL REGULATOR ** (Boner_Ben)
ok thanks for that info.
Old Oct 16, 2006 | 05:26 PM
NooB
darn nobody uses this furl pump then.
Old Oct 16, 2006 | 07:30 PM
NooB
Old Oct 16, 2006 | 07:55 PM
B18 CYA's Avatar
I used their pump and loved it. Way quieter than an aeromotive. My buddy has an aeromotive and wished he had this one instead since its so much quieter. No problems with this pump . power level made on this pump is in my sig
Old Oct 16, 2006 | 09:44 PM
NooB
Default Re: (B18 CYA)
thanks.ok i made the pruchase thanks guys..
kornerk12
Oct 15, 2006 03:58 PM
Lsos
Jan 16, 2003 11:56 AM
E Swift
Nov 4, 2002 07:55 PM
