Suspension & Brakes Theory, alignment, spring rates....
omni uca camber kit
Old Oct 16, 2006 | 12:47 PM
jdmzoom's Avatar
Default omni uca camber kit
i have the omni power camber kit and it is set to the maximum but i still have about 1.5 degree negative camber. is this supposed to happen? did i install it wrong? maybe i should take them out and reinstall them to see if it'll help. my car is lowered 2.75" on h&r race springs and kyb agx shocks. thanks, any help is appreciated.
Old Oct 16, 2006 | 01:12 PM
Downey's Avatar
Default Re: omni uca camber kit (jdmzoom)
i think with the omni kit you can get close to 0 (Zero) or -.5
The ball joints are pulled all the way out?
how much did u have with the stock arm?
maybe somethings bent and thats whats causing the negative camber.
Old Oct 16, 2006 | 02:12 PM
dvp's Avatar
dvp
Default Re: omni uca camber kit (Downey)
How are you lowered 2.75 when the springs are 2" front 1.75" rear?
If you really are 2.75" lowered, that's the problem...it's too low.
Old Oct 18, 2006 | 03:20 PM
jdmzoom's Avatar
Default Re: omni uca camber kit (dvp)
my mistake, i mean't 2.5" front and 2.25" rear. is it really too low? when i bought them they said +-4 degrees. i tried to redo them yesterday but they still came out the same, bolts torqued to specs and everything... i'm just going to try some skunk2's now...
Old Oct 18, 2006 | 04:16 PM
Downey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmzoom &raquo;</TD></TR><TR><TD CLASS="quote">my mistake, i mean't 2.5" front and 2.25" rear. is it really too low? when i bought them they said +-4 degrees. i tried to redo them yesterday but they still came out the same, bolts torqued to specs and everything... i'm just going to try some skunk2's now...</TD></TR></TABLE>
skunk2 and omni's are the same. we have both on our cars and there is no difference.
lazyxazianxboi
Nov 1, 2004 08:32 AM
madcrossover
Oct 19, 2004 10:05 AM
revenge
May 14, 2004 07:23 PM
EriK20
Aug 21, 2003 05:47 PM
1bar
Aug 22, 2002 09:12 AM
