no crank
Old Oct 16, 2006 | 11:09 AM
keepitngga1's Avatar
Default no crank
i tried startin my car today and it wouldnt even crank over..i heard a little buzzing sound comin from inside the car and the battery light on my cluster was blinking..i checked my battery and its at about 12v which is good enough. any idea on wha it can be
Old Oct 16, 2006 | 11:40 AM
Perfectionist's Avatar
Default Re: no crank (keepitngga1)
A battery may read 12 volts under no load, but can't produce the current required to crank the engine. Check the voltage while cranking. If it holds near 12 volts, check your cables at both ends for good clean connections.
Overall, I think your battery is weak.
Old Oct 16, 2006 | 02:03 PM
Default Re: no crank (Perfectionist)
i checked it and its ok.. any other ideas?
Javao007
Aug 5, 2012 01:19 PM
03ep3sicivic
Jun 28, 2009 08:05 AM
Inextricabledrvr
Dec 16, 2008 09:45 PM
philkehn
13
Sep 7, 2006 03:58 PM
JDMxSpawn
Jul 5, 2005 06:30 PM
