need help?????
Old Oct 15, 2006 | 06:47 PM
d_a_b's Avatar
Default need help?????
ok i have a 93 del sol with a 93 teg b18b i just got the car so dont know much about it. but when you first start it up in the mornings it smokes bad you can smell alot of gas and runs like sh-t till it worms up. but even then you can still smell fuil bad. what could it be ?????
Old Oct 15, 2006 | 07:00 PM
bustedefhatch's Avatar
Default Re: need help????? (d_a_b)
is there a cel? is there a cat converter on the car?
Old Oct 15, 2006 | 07:05 PM
d_a_b's Avatar
Default Re: need help????? (bustedefhatch)
no i cut it off today it was stoped up u could not see through it but you can still smell gas fumes. but it seams to run better
Old Oct 15, 2006 | 07:58 PM
d_a_b's Avatar
Old Oct 17, 2006 | 11:53 AM
d_a_b's Avatar
still nead help can some one tell me what i nead to do
Old Oct 17, 2006 | 07:56 PM
d_a_b's Avatar
Old Oct 17, 2006 | 09:19 PM
2DoorBandit's Avatar
i would put i new cat on that would help then maybe do a tuneup /check timing
Old Oct 17, 2006 | 09:23 PM
cambopheonix56's Avatar
Default Re: need help????? (2DoorBandit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit &raquo;</TD></TR><TR><TD CLASS="quote">i would put i new cat on that would help then maybe do a tuneup /check timing</TD></TR></TABLE>
Thats a start. What ecu are you using?
Old Oct 17, 2006 | 10:28 PM
Default Re: need help????? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a start. What ecu are you using?</TD></TR></TABLE>
i knew i couldent remember something
Old Oct 18, 2006 | 04:24 AM
d_a_b's Avatar
i did a tune up on the motor and it still does it the timing is good.
and the ecu is the stock ecu that came out of the teg the motor
came out of
Old Oct 18, 2006 | 10:29 AM
slow eg6's Avatar
this may sound stupid but i had the same problem...i mean mine still smokes but i'm running straight pipe...gas fumes may be coming from the fuel rail...check that
Old Oct 18, 2006 | 07:54 PM
d_a_b's Avatar
Default Re: need help????? (slow eg6)
i have changed every thing i could think off. all new tune up timing is good
i also tride a new ecu and it still do's the same thing. i am geting way to much fuel
when the motor is cold it smells like raw gas coming out the muffler with alot of smoke. but when it worms up it run good you can still smell fuel but not as bad
can some one plzzzz help thanks
Old Oct 18, 2006 | 09:22 PM
maybe u have a leak in a fuel line or tank or the line that goes to the charcol canister cause only the fumes go through that one if i understand
Old Oct 18, 2006 | 09:31 PM
d_a_b's Avatar
i do not have the charcol canister hooked up
Old Oct 19, 2006 | 08:04 AM
d_a_b's Avatar
still cant find out what it is. plzzz help thanks
Old Oct 19, 2006 | 06:39 PM
d_a_b's Avatar
Old Oct 22, 2006 | 09:44 PM
d_a_b's Avatar
ttt
Old Oct 22, 2006 | 11:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d_a_b &raquo;</TD></TR><TR><TD CLASS="quote">i do not have the charcol canister hooked up</TD></TR></TABLE>
well this is most likely whre your smelling the gas from..where did u disconnect to vent tube from the tank to the canister
Uncle Willie
Nov 21, 2007 02:17 PM
drummr6
Dec 15, 2005 10:18 PM
POWERINTEGRA
Oct 18, 2004 05:21 PM
91hatch_on17's
Apr 28, 2004 06:26 PM
white_eg
Sep 20, 2003 08:00 AM
