PM7 or PG7
Old Oct 15, 2006 | 06:33 PM
stivic's Avatar
Default PM7 or PG7
Whats the difference between the two... other than the PG7 is an integra ECU and PM7 is the ZC ECU. I have a JDM ZC engine and am running a PG7 is this fine I do have 4 cel codes on
Codes 6 - Coolant temp, 7 - throttle angle, 9 - No1 cylinder position, and 10 - air intake temp
If I were to switch to a PM7 would it help any?
By the way car runs like **** wont rev past 2k and barely revs at all with backfiring
Old Oct 15, 2006 | 06:41 PM
Tippyman's Avatar
Fix the codes. They aren't cause of the ECU, they're cause you have sensors malfunctioning.
Old Oct 15, 2006 | 06:42 PM
cbp_crx's Avatar
Default Re: (Tippyman)
yeah, the ecu wont make a difference, just get all of the codes fixed, and you should be good. i used to have a zc, and ran that ecu, and it worked fine.
Old Oct 15, 2006 | 06:57 PM
stivic's Avatar
Default Re: (cbp_crx)
Ok well I started troubleshooting code 9 first - No1 cylinder position...
I changed the timng belt because it was loose probably skipped a tooh or something. No1 cylinder was full of oil and the gap on the spark plug had been smashed in so I regapped it since the plug looked fine. I then let the oil fall out of the cylinder. I checked resistance from the connector on the dizzy, that turned out fine. I went in the cabin and checked resistance on that side of the harness and I wasn't getting between 350-550, it read around 3009, weird to me. I think it may be that spark plug wire going to the No1 cylinder it was drenched in oil to begin with.
Any suggestions?
Old goat
Jun 30, 2011 04:05 AM
661rex89si
Apr 12, 2011 01:04 AM
vanos_pusha
May 13, 2006 12:29 PM
vmm
Jun 24, 2004 07:36 PM
tdc
Feb 23, 2002 08:32 AM
