nut wont budge. - adding lowering springs
Old Oct 15, 2006 | 06:13 PM
pli's Avatar
pli
Default nut wont budge. - adding lowering springs
there is this nut in behind the rotors, connected to the coilover. im trying to take the whole coilover suspension off to add the springs. the nut wont come off. what lbs. torque wrench do you think i could use to take it off or is it not possible and i need an air compressor with the gun?
Old Oct 15, 2006 | 06:17 PM
Sleepy_Red_hatch's Avatar
Default Re: nut wont budge. - adding lowering springs (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">there is this nut in behind the rotors, connected to the coilover. im trying to take the whole coilover suspension off to add the springs. the nut wont come off. what lbs. torque wrench do you think i could use to take it off or is it not possible and i need an air compressor with the gun?</TD></TR></TABLE>
dont use a torque wrench to take things off....use a breaker bar and a steel pipe....or if you're like me, an impact gun + air compressor
Old Oct 15, 2006 | 06:20 PM
t0p_sh0tta's Avatar
If you're not man enough to get it off with a boxed/open ended wrench or even a ratchet, get a breaker bar.
Torque wrenches are for tightening nuts, bolts, etc to a specific point.
Old Oct 15, 2006 | 06:21 PM
pli's Avatar
pli
Default Re: nut wont budge. - adding lowering springs (Sleepy_Red_hatch)
yea. i was wondering about the impact gun and the air compressor. how much would it cost to get a decent set. or how many gallons of air or hps would i need to atleast take the nut off. i see sears selling these for like 150-200 bucks. are those strong enough?they have like 1hp with 12 gallons of air. or 1.5hp with 15 gallons.
Old Oct 15, 2006 | 06:22 PM
Si_chRis's Avatar
I heard of using this method from a friend if you are using a impact. Tighten the bolt, then loosen, tighten, loosen until it becomes loose. Supposedly it helps and will prevent your bolt will from getting stripped.
Old Oct 15, 2006 | 06:26 PM
pli's Avatar
pli
Default Re: nut wont budge. - adding lowering springs (EM1_ChRiS)
sigh. my friends were all using a gorilla wrench to try and budge that nut off.
Old Oct 15, 2006 | 06:29 PM
pat92si's Avatar
i had the same problem as you when i did my rear suspension, unfortunatley i ended up snapping the bolt and had to drill my *** off for a long time. if you use the breaker bar just be careful and try to not snap the head of the bolt off. hope you have better luck than i did
Old Oct 15, 2006 | 06:32 PM
pli's Avatar
pli
Default Re: nut wont budge. - adding lowering springs (pat92si)
better than paying 190 labor fee to do it at a local shop right?
Old Oct 15, 2006 | 06:42 PM
Si_chRis's Avatar
I know sears sells a battery imapct wrench that throws about 100 ft lb of torque or somthing like that. It's close to 300 but it battery pack powered. But if you want to buy a compressor and gun, it is a little cheaper
Old Oct 15, 2006 | 06:45 PM
pli's Avatar
pli
so about the question i asked up there. does it matter what gallons of air or hp it has to be, for the air compressor?
Old Oct 15, 2006 | 06:48 PM
Si_chRis's Avatar
The more air the better, it will give your gun contant power if you are using the gun constantly. But anything more than 5 gallons is good enough
Old Oct 15, 2006 | 06:49 PM
SOHCejcivic's Avatar
ahhh deleted my post!
use air tools for sure. anything that'll get 100psi will work (i usually run it up to 120) use a real impact too. on past experience, 3/8s will pretty much waste your time...i usually break out my 1/2....just gotta be careful with it.
Old Oct 15, 2006 | 06:57 PM
pli's Avatar
pli
Default Re: nut wont budge. - adding lowering springs (SOHCejcivic)
how's this kit from sears. comes with air compressor and an impact gun.
http://www.sears.com/sr/javasr...e=Yes
Old Oct 15, 2006 | 07:22 PM
cambopheonix56's Avatar
Perfect.
Old Oct 15, 2006 | 08:07 PM
instrument's Avatar
drive it to your nearest shop, ask them to loosen them, my local shop back at home would do it for free if i came in bright and early.
Old Oct 15, 2006 | 08:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">how's this kit from sears. comes with air compressor and an impact gun.
http://www.sears.com/sr/javasr...e=Yes</TD></TR></TABLE>
welcome to manhood, now, if that puny gun cant take it, find a IR 2135Ti on ebay for cheap (mine was 200 shipped) i guarantee you, its the LAST impact gun you'll ever need
Old Oct 15, 2006 | 11:12 PM
tempsohc's Avatar
i can vouch...the titanium IR is the shiet.....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
welcome to manhood, now, if that puny gun cant take it, find a IR 2135Ti on ebay for cheap (mine was 200 shipped) i guarantee you, its the LAST impact gun you'll ever need</TD></TR></TABLE>
Old Oct 15, 2006 | 11:22 PM
Taimaishui14's Avatar
Thats the same one my dad has. I use it quite a bit, works everytime.
Old Oct 15, 2006 | 11:26 PM
chrisw85's Avatar
Ingersoll-Rand titanium 2135QTi (quiet model) ftw! Great great impact wrench that many others will vouch for.
and a 30+ gallon tank, oil drive, heck, just get an 80 gallon tank and stuff 'er in the corner. Might need 240v though. And get a refrigerated air dryer; moisture free air for your tires and paint jobs! ok ok thats not all necessary but it'd be nice.
Old Oct 16, 2006 | 05:09 AM
1slow4dr's Avatar
i'd use an air gun and maybe a torch
Old Oct 16, 2006 | 06:13 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: nut wont budge. - adding lowering springs (1slow4dr)
did you try tapping the nut with a hammer? Shock the threads and maybe it will come off easier. I do it all the time as a machine tech.
Old Oct 16, 2006 | 06:28 AM
instructor74's Avatar
Default Re: nut wont budge. - adding lowering springs (ek forever guy)
It is not at all uncommon for the lower bolt to rust in the bushing sleeve then you just end up braking the bolt head off. Be prepared with new bolts ready to go there only a few $ from honda. Oh yeah make sure you are working on the right end of the bolt most of the shocks have the nut welded to them
vinuneuro
Jun 9, 2007 02:59 AM
vidanator
May 20, 2005 04:46 PM
mymeatb18"
Jan 17, 2005 08:56 PM
EnKidu
Nov 19, 2004 11:22 PM
94integrablur
Jun 13, 2002 02:39 PM
