How do I know if I have a LSD?
Old May 3, 2002 | 09:21 PM
fred92htch's Avatar
Default How do I know if I have a LSD?
I got my GSR done today and finally got to drive it. Still waiting for my cat back so I'm stock from the test pipe back. WOW, what a monster! I'm so glad I went GSR. Torque is incredible. Anyway, it's a JDM motor and I don't know if it has the lsd or not. Is there an easy way to tell?
Old May 3, 2002 | 09:24 PM
tSuperbike69's Avatar
Default Re: How do I know if I have a LSD? (fred97gle)
One way is to look through your diff before you would have put your axles in and if you can see throught them then you have lsd if there is a bar through the middle then you dont. Lsd in a gsr is very rare even in a gsr.
Old May 5, 2002 | 10:01 AM
TruePlayaz114's Avatar
Default Re: How do I know if I have a LSD? (tSuperbike69)
He's right. If you can see straight thru then you have LSD. Right before i put in my swap my mechanic pointed that out to me so i can see for myself and I do have it. I just haven't learned how to use it to well and the launches but that takes time i guess.
Old May 5, 2002 | 11:29 AM
Houston Hatchback's Avatar
Default Re: How do I know if I have a LSD? (TruePlayaz114)
the true way to check if you have lsd is jack the car up, put it in gear , turn one wheel- if the other spin the same way then its a lsd...or look for the lsd stamp on the tranny thats my 2 cents thanks for your time.
Old May 6, 2002 | 07:03 AM
Mista Bone's Avatar
D Tranny Guru
this might help..........
Old May 6, 2002 | 09:04 AM
rolow's Avatar
Default Re: How do I know if I have a LSD? (Houston Hatchback)
Is this true?
Does that include aftermarket lsd's to?
Old May 6, 2002 | 10:02 AM
Katman's Avatar
Default Re: How do I know if I have a LSD? (rolow)
Is this true?
it is a way to tell, but the sure way is buy peeking through the diff hole. Another way is by checking to see if there's an LSD stamp on the front tranny casing.
more info here:
http://www.ff-squad.com/LSDcheck!.htm
jazmie
Transmission & Drivetrain
Feb 1, 2010 10:20 PM
poormans_typer69
Dec 20, 2006 10:59 AM
jdub db8
Jul 26, 2004 10:55 AM
Aids333
Aug 20, 2003 07:49 AM
