how to clean pistons with out sand paper//?
Only two ways:
By the book: Get a "piston scaper"
Or Average Joe: Scotch Brite pad and some elbow grease. I promise it won't come off by looking at it! Some companies even make scotch brite on for an end grinder.
wow, you should put down the sandpaper, fill your bathtub full of water, and go drown your self. you NEVER use sandpaper to clean a piston. Waste of sperm
Furthermore, didn't you have another post asking if you should buy those pistons/if they will work in your engine, and everybody said they wouldent w/o having the block bored out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic »</TD></TR><TR><TD CLASS="quote">wow, you should put down the sandpaper, fill your bathtub full of water, and go drown your self. you NEVER use sandpaper to clean a piston. Waste of sperm
Furthermore, didn't you have another post asking if you should buy those pistons/if they will work in your engine, and everybody said they wouldent w/o having the block bored out...</TD></TR></TABLE>
OWNED
OWNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Ugh. IBTL. Where has the EF Forum gone to?
Where are you Vap?</TD></TR></TABLE>
the sad thing is that there is actually some tech in here
If you want higher compression don't clean that carbon off
I used some acietone(sp?) and scotchbrite pad...seafoam may work too but its just petolium so save the cash and ge some gas instead or WD-40 all will work
yea i did have a nother post ..but got zero answers..this post workt well...thanx 4 all the reply's....will show pics wen im done...4 pistons...1 (wd40) 2 (Oven cleaner) 3( sand paper ) 4( Scotch Brite pad ) will post pics of all 4 pistons tmrww..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex »</TD></TR><TR><TD CLASS="quote">so just bring the pistons to honda or napa and thell noe wich one are the rite rings .PS-- not trying 2 be a noob thers just somethings i dont noe</TD></TR></TABLE>
You're being perfectly fine. People on here trying to be tough and yelling "owned!" and gay **** like that are ruining the thread.
