NEED HELP ASAP!
Old Oct 15, 2006 | 05:09 PM
vi3tromanc3r's Avatar
Default NEED HELP ASAP!
I was trying to do a compression test and the 18mm side where you plug it into the motor got stuck inside and i cant get it out, happen to anyone? anyone know how to get it out? much appreciated.
Old Oct 15, 2006 | 06:29 PM
Si_chRis's Avatar
Default Re: NEED HELP ASAP! (vi3tromanc3r)
Does it have a hex shape on that part that is stuck? If it does, maybe a spark plug socket?
Old Oct 15, 2006 | 06:33 PM
Default Re: NEED HELP ASAP! (EM1_ChRiS)
yea it has a hex shape where it is stuck but its an 18mm and i tried 18mm sockets and they dont fit in the cylinders.
Old Oct 15, 2006 | 07:10 PM
crawfo661's Avatar
that happened to me, grind down a cheap 18 mm socket till the walls are real thin and it will fit. use a bench grinder, keep the walls smooth so that the socket doesn't get stuck good luck man
Old Oct 15, 2006 | 08:18 PM
Default Re: NEED HELP ASAP! (crawfo661)
how deep does the 18mm socket has to be?
Old Oct 15, 2006 | 08:29 PM
crawfo661's Avatar
depends on ur specific tester, i used a standard depth one
Old Oct 15, 2006 | 08:37 PM
alright thanks. hm i heard you can buy thin walled 18mm sockets. is that true? will these actually fit in the cylinders.
Old Oct 16, 2006 | 11:34 AM
Si_chRis's Avatar
Does the hose part connecting to the gauge twist on to the part that is stuck? I had the bottom part stuck on too before but i twisted the hose back on then loosened it and it came out as one piece.
Old Oct 16, 2006 | 11:59 AM
yea it is, i been trying to use the hose but everytime i unscrew is the hose comes out by itself and leaves the other part inside.
Old Oct 16, 2006 | 02:11 PM
well i solved it. thx everyone.
gjbraun
Jun 18, 2012 10:57 AM
transitions
May 14, 2007 03:58 PM
drumminforev
Jan 21, 2007 08:59 AM
Eluzion
Dec 8, 2002 10:33 PM
M.A.R.C.
19
Jul 9, 2002 06:37 PM
