password jdm fog light installation
Old Oct 15, 2006 | 03:55 PM
shifts's Avatar
Default password jdm fog light installation
k i need some help on installing this. i followed the intructions that came w/it but it seem it wasnt gettin any pwr. ive seen the diy on the depo fogs but the wiring is completely diff. ne help? thanks!
Old Oct 15, 2006 | 05:05 PM
SOHCejcivic's Avatar
Default Re: password jdm fog light installation (shifts)
the plug on the accesory port on the fuse panel. i can bet money that it's not plugged in all the way. i did the same thing.
it feels like it's plugged in, but it's probably not. push on it really hard and it'll click in.
Old Oct 15, 2006 | 05:52 PM
kidphantastick's Avatar
what i did 2 my fogs is wire them to my hazards
Old Oct 15, 2006 | 05:54 PM
Eran's Avatar
HT White Ops
Default Re: password jdm fog light installation (kidphantastick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidphantastick &raquo;</TD></TR><TR><TD CLASS="quote">what i did 2 my fogs is wire them to my hazards</TD></TR></TABLE>
Why?
Old Oct 15, 2006 | 05:56 PM
Felliph3's Avatar
Default Re: password jdm fog light installation (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Why? </TD></TR></TABLE>
So that he is different from everyone,its good to see change. Its not a bad idea other than just not having fogs.
Old Oct 15, 2006 | 05:58 PM
Eran's Avatar
HT White Ops
Default Re: password jdm fog light installation (Felliph3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 &raquo;</TD></TR><TR><TD CLASS="quote">So that he is different from everyone,its good to see change. Its not a bad idea other than just not having fogs.</TD></TR></TABLE>
Shut the hell up, retard.
Wiring foglights to a switch that already has a purpose instead of wiring to a foglight switch isn't different, it's moronic. What are you now, the defender of bad ideas? Ran out of your own?
Old Oct 15, 2006 | 06:07 PM
shifts's Avatar
Default Re: password jdm fog light installation (SOHCejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">the plug on the accesory port on the fuse panel. i can bet money that it's not plugged in all the way. i did the same thing.
it feels like it's plugged in, but it's probably not. push on it really hard and it'll click in. </TD></TR></TABLE>
there r two em so i guess ill try pushin harder. also there isnt ne pwr cables? just the two ground ones correct?
Old Oct 15, 2006 | 06:20 PM
Eran's Avatar
HT White Ops
you should have a red wire going DIRECTLY to the battery or another fused 12v source.
Old Oct 15, 2006 | 06:35 PM
should have a wire that goes from the battery to the relay, relay to the fog harness (that has a ground in it) harness to the inside of the car. one end goes to the plug, the other goes to the fuse panel (also has a ground hanging off of it) the little connector that goes to the accessory plug (second from the right i saw somewhere ) it'll click in, but it has to go in further.
Old Oct 15, 2006 | 07:06 PM
shifts's Avatar
dont recall a wire goin from the battery to the relay. one ground is up front by the fogs and the other is inside. two connectors r actually present. ill post pics of the harness hopefully later on tonight.
Old Oct 16, 2006 | 09:15 AM
shifts's Avatar
ok i finally got em on now except only w/the parking lights. once i turn on the actual head lights they go off. ne solutions?
Modified by shifts at 12:29 PM 10/16/2006
Old Oct 16, 2006 | 09:49 AM
2coupes's Avatar
put it in the E spot in the interior fuse
Old Oct 16, 2006 | 10:36 AM
shifts's Avatar
k thanks guys got em now.
turnsignalandy
Jan 7, 2007 03:01 PM
DFW
34
Oct 25, 2006 12:15 PM
g2xsi
Jan 8, 2006 01:10 PM
philosofy1
12
Mar 26, 2005 06:59 PM
Finger Lickin' good
Oct 26, 2004 02:36 PM
