95 H22 civic NO REVERSE
Old Oct 15, 2006 | 03:12 PM
H22Civic9's Avatar
Default 95 H22 civic NO REVERSE
Hey guys i just got done my h22 swap in my 95 civic hatchback i tookl it out last night for a little bit and i had reverse before i left my house by the time i had got back to my house that night the reverse was gone i cant even use reverse i have no idea what could have happend please help thanks
Old Oct 15, 2006 | 07:22 PM
pat92si's Avatar
Default Re: 95 H22 civic NO REVERSE (H22Civic9)
hows the tranny fluid?, did you try going into another gear and then reverse.
Old Oct 15, 2006 | 07:24 PM
poison's Avatar
are you just not able to get it into gear?
what happens?
cable or bracket might have slipped off or something.
Old Oct 15, 2006 | 07:47 PM
sikciv666's Avatar
Default Re: 95 H22 civic NO REVERSE (poison)
ive read about this before,,,check the shifter box, mabye how the box is lined up
Old Oct 16, 2006 | 01:33 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">are you just not able to get it into gear?
what happens?
cable or bracket might have slipped off or something. </TD></TR></TABLE>
what i was thinking
Old Oct 16, 2006 | 08:44 AM
H22Civic9's Avatar
yea tranny fliud is good i checked its not that
Old Oct 16, 2006 | 08:45 AM
H22Civic9's Avatar
Default Re: 95 H22 civic NO REVERSE (sikciv666)
yea i cant get it into gear its like i am blocked out of it it wont even go in if the car is off and when i use the clutch it wont go in i have no idea what is wrong?????
Old Oct 16, 2006 | 10:51 AM
j spec's Avatar
i had that same problem with several h/f series trannies. they usually result from a bent shift fork or the slider in the transmission burs up on the end, keeping it from selecting reverse. common symptoms include difficulty getting into 5th. Thats actually why i ditched the H B
Old Oct 16, 2006 | 02:42 PM
H22Civic9's Avatar
Default Re: 95 H22 civic NO REVERSE (roma's GSReg6)
Do i have to take the whole tranny out to fix the shift fork or the slider or can i take off the cap where the shift linkages are and connect to ????
Old Oct 17, 2006 | 07:52 AM
j spec's Avatar
you got to pull the whole tranny apart. and if its anything like mine was its easier to pull the whole engine.
Tayter
Jan 23, 2009 05:17 AM
quicksweepEX
Dec 5, 2007 12:45 PM
MyLilCivic
Apr 7, 2007 01:36 PM
accordking
Dec 4, 2002 03:35 AM
