OBD1 intake mani on OBD2
Old Oct 15, 2006 | 03:00 PM
95jeremie's Avatar
Default OBD1 intake mani on OBD2
ok so a friend needs to replace his intake manifold (his is cracked). i have a d16z6 IM and was wondering if it could be used. if so what would have to be changed over?
Old Oct 15, 2006 | 04:28 PM
95jeremie's Avatar
Default Re: OBD1 intake mani on OBD2 (95jeremie)
bump
Old Oct 15, 2006 | 06:27 PM
md88hfcrx's Avatar
z6 will work
Old Oct 15, 2006 | 06:44 PM
dustinO's Avatar
the z6 will work fine
as long as it is going on a D series
Old Oct 15, 2006 | 06:45 PM
95jeremie's Avatar
Default Re: OBD1 intake mani on OBD2 (md88hfcrx)
i figured that it will work
are there any sensors or anything that need to be changed over?
they are not the "same"
thanks for the reply
Old Oct 15, 2006 | 06:46 PM
95jeremie's Avatar
can i use the z6 throttle body?
Old Oct 15, 2006 | 07:03 PM
Jonknee's Avatar
Is the crack small enough to be welded,
Old Oct 16, 2006 | 08:41 AM
95jeremie's Avatar
Default Re: OBD1 intake mani on OBD2 (La-Quiete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-Quiete &raquo;</TD></TR><TR><TD CLASS="quote">Is the crack small enough to be welded, </TD></TR></TABLE>
no
the auto parts store gave him the wrong gasket and he didn't notice. it cracked the coolant port off... like all the way off
Old Oct 16, 2006 | 12:16 PM
95jeremie's Avatar
bump
Old Oct 17, 2006 | 09:49 AM
95jeremie's Avatar
BUMP!
Old Oct 17, 2006 | 10:56 AM
eda6's Avatar
pics.
Old Oct 17, 2006 | 12:52 PM
Jonknee's Avatar
Default Re: OBD1 intake mani on OBD2 (eda6)
Not sre if i remember corretly but the obd0 eacv is two wire and the obd2 eacv is 3 wire, maybe you can switch eacv's. that's the only difference i knwo of.
blueg6
Jan 26, 2009 02:18 PM
BlueTeg01
Mar 27, 2007 06:50 AM
user 98292739
Apr 4, 2005 05:46 AM
DOHClessEF-9
Jan 7, 2005 07:48 PM
Duffman1984
Apr 12, 2004 10:47 PM
