is this the ground wire that goe to the thermostat h22a1?
Old Oct 15, 2006 | 02:46 PM
oranginal's Avatar
Default is this the ground wire that goes to the thermostat h22a1?
this is not my pic but i think it is a lude. is this where the ground wire for the thermostat is suppose to be at?
*result of this post: the ground in the pic is not the ground of the thermostat for the h22a1 lude, the pic i found is not even a lude. but i just wanted to make sure i had the right place.
the right place of the ground is located below the vtec solinoid facing the passenger side.
Modified by oranginal at 11:47 PM 10/15/2006
Old Oct 15, 2006 | 04:11 PM
TheWalrus's Avatar
mine is closer to the distributor like under the vtec solenoid...and the bolt head faces the pass side...but who cares, a good ground is a good ground
deff not a lude, the battery is in the top left of that pic, i think civics and tegs have it there
Old Oct 15, 2006 | 04:15 PM
fastludeh22's Avatar
Default Re: (weenie)
if ur talking about harness ground, yes. i also grounded it to the frame to make sure it had a good ground
Old Oct 15, 2006 | 07:45 PM
oranginal's Avatar
Default Re: (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weenie &raquo;</TD></TR><TR><TD CLASS="quote">mine is closer to the distributor like under the vtec solenoid...and the bolt head faces the pass side...but who cares, a good ground is a good ground
deff not a lude, the battery is in the top left of that pic, i think civics and tegs have it there</TD></TR></TABLE>
that's where mine was, i just wanted to make sure i had the right place because i had honda change the thermostat and i wanted to make sure everything was in it's place.
thanks
Old Oct 16, 2006 | 06:13 AM
flyrod's Avatar
Default Re: (oranginal)
On the H22, the engine wire harness grounds to the head near the thermostat housing.
Old Oct 16, 2006 | 07:01 AM
oranginal's Avatar
Default Re: (flyrod)
post pic please
M2B4
Oct 23, 2007 07:15 PM
Felliph3
Oct 18, 2006 10:02 AM
SunkistRex
Mar 15, 2004 01:12 PM
azn_outlaw
Aug 13, 2003 11:02 PM
garyyam
Oct 22, 2002 04:05 PM
