riding cluch?????
Old Oct 15, 2006 | 01:36 PM
ic89's Avatar
Default riding cluch?????
i recently put a competion stage 1 clutch in my 92civic, i am new to drivign stick would like to noe if i am riding my clutch wen releasing out of 1st gea, i rev to about 1800 and let my clutch go within 2.5 seconds, is this considered riding the clutch ??? if it matters my car idles at only 600- 700
Old Oct 15, 2006 | 01:53 PM
TunerShark's Avatar
Default Re: riding cluch????? (ic89)
"riding the clutch" is when you rest your foot on the clutch pedal when cruising, as long as you keep your foot off the clutch when you cruise youre not "riding the clutch"
;D
Old Oct 15, 2006 | 01:56 PM
-JSpecEk*9-'s Avatar
Default Re: riding cluch????? (TunerShark)
why are you revvn so high to take off? 1800 seems high to me or ur jus a beginner right keep pratice.
ic89's Avatar
so technically even if i am in 3rd gear and my foot is even a little bit on the clutch pedal that is bad for my clutch?
Old Oct 15, 2006 | 01:58 PM
ic89's Avatar
wut is concidered not high is 1400 ok?
blackdelslo's Avatar
there is no reason to rest your foot on the clutch unless your about to shift, you may be putting slight pressure on it, therefore disengaging it slightly which would not be good over time.
Old Oct 15, 2006 | 02:15 PM
ic89's Avatar
Default Re: riding cluch????? (delLudeVTEC)
wut is concidered good rpms wen getting otu of 1st gear???
Old Oct 15, 2006 | 02:22 PM
SuperSteve737's Avatar
Whatever you can without killing the car. Just practice. It is possible to "get out of 1st gear" without any gas. Just have to let it out slowly.
You will find a good balance between the high revs and not killing the car with practice.
Old Oct 15, 2006 | 02:33 PM
ic89's Avatar
Default Re: (SuperSteve737)
if i get out of 1st with even a thousand rpms and it does nto stall but my car shakes is that ok 4 my car???
Old Oct 15, 2006 | 03:06 PM
Default Re: (ic89)
No. Violent shaking is bad. Quit typing, get in your car, drive to an empty parking lot, and just practice starting. You don't even have to go to an empty lot, just practice in your subdivision.
Old Oct 15, 2006 | 03:14 PM
MattsGreenEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">"riding the clutch" is when you rest your foot on the clutch pedal when cruising, as long as you keep your foot off the clutch when you cruise youre not "riding the clutch"
;D</TD></TR></TABLE>
meece0927
Jul 2, 2013 08:15 AM
Honda Rules
Jun 30, 2007 04:00 PM
steve_s
Apr 1, 2003 06:43 PM
Drag3GSR
Jun 15, 2001 06:01 AM
