Gas gauge problem
Old Oct 15, 2006 | 01:04 PM
wolferine358's Avatar
Default Gas gauge problem
hello all.does anyone with a 92-95 civic noce the gas gauge when im driving and i make a left curve turn,the gas gauge goes up a lil.when a make a right curve turn the gas gauge goes down.this mostly happens when im the highway.anyone have this prob or know of a solution?
Old Oct 15, 2006 | 01:24 PM
MJ0LNIR's Avatar
Default Re: Gas gauge problem (wolferine358)
In the interest of a quick answer I offer my limited knowledge...
If I remember correctly, the gas guage is connected to a float in the gas tank which connects up to some other electrical equipment to make the needle on your gas guage work. As you fill the tank, the float goes up, and the needle does too. Likewise as you use the gas up. So, when you go into a turn, the gas in the tank is going to all move to the outside of the turn. If the float isn't mounted directly in the center of the tank (which it likely isn't), that's going to give you a different reading depending on the direction of your turn.
For example, if your float is mounted left of the center of the tank, and you make a right turn, all the gas will slosh to the left side of the tank and the gauge will read higher.
Like I said, I'm no tech, just offering a quick answer. My 92 hatch does this all the time also. If it's happening a lot when your tank is full, though, then there shouldn't be a lot of sloshing around going on and then I might be worried. Otherwise don't worry about it.
Old Oct 15, 2006 | 01:25 PM
Eran's Avatar
HT White Ops
The solution would be a baffled race tank.
Or just dealing with it like every other car on the road.
PhoenixDownVII
14
Jun 24, 2008 10:49 PM
Apotheosis
Apr 6, 2008 01:31 PM
rhgindc
10
Apr 27, 2007 12:32 AM
Nongan
Oct 29, 2006 01:15 PM
SnowSurfer
Aug 26, 2004 09:04 AM
