Taking IM off ?
Old Oct 15, 2006 | 12:57 PM
lude98SH's Avatar
Default Taking IM off ?
Yesterday I was going to install my hondata IM gasket I had the fuel rail and injectors out and had all the nuts on the top of the IM off. I went to get the ones on the bottom of the manifold off and it was a PITA. It was late so I just said forget it for now. How did you guys get them off because there was like zero room to work ?
Old Oct 15, 2006 | 03:13 PM
Hawkze_2.3's Avatar
Default Re: Taking IM off ? (lude98SH)
Have a couple different wrenches (open-ended, 12-point, etc) and go at it from below....I usually only get like 1/8 turn or something intil it's loose
Old Oct 15, 2006 | 03:26 PM
GrimLude's Avatar
air ratchet works nice
Old Oct 15, 2006 | 07:34 PM
BlUAc's Avatar
Default Re: Taking IM off ? (GrimLude)
you can fit an air ratchet in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Have a couple different wrenches (open-ended, 12-point, etc) and go at it from below....I usually only get like 1/8 turn or something intil it's loose </TD></TR></TABLE>
^^^^^ thats what I did and only took a half hour to do the whole R&R surprised myself
Old Oct 20, 2006 | 02:43 PM
lude98SH's Avatar
Default Re: Taking IM off ? (BlUAc)
theres no way in hell i can get an air rachet in there. It is SOO tight in there. And From below would prolly be even harder. There so much **** in the way i cant get to the 2 center nuts.
Old Oct 20, 2006 | 02:45 PM
soundbomber's Avatar
you have to go from below
Old Oct 20, 2006 | 02:46 PM
lude98SH's Avatar
Default Re: Taking IM off ? (soundbomber)
Do i have to move something because theres still no room from under there ?
Old Oct 20, 2006 | 06:24 PM
94vtirozguy's Avatar
you can get to the bolts on the underside of the IM easily. There is space. You just need to try different angles.
Make sure you have varying length extension bars and it is not that hard.
Old Oct 20, 2006 | 08:20 PM
K-Spec's Avatar
did you try going from the TB side? did you remove your Intake? and cruise control?
Old Oct 20, 2006 | 10:35 PM
lude98SH's Avatar
Default Re: Taking IM off ? (khalal538)
Yea Cruise is out and Intake is out. Fuel rail injectors are all out. I got all the nuts besides the 2 center ones on the bottom.
Old Oct 20, 2006 | 10:39 PM
MadCityLude
Guest
Posts: n/a
Remove the black vaccum box and support brace? With those out there should be plenty of room.
Old Oct 20, 2006 | 10:54 PM
K-Spec's Avatar
once you remove the old one, to save you all the hassle of putting it back, put a smaller IM in this time...ie. euro-r hehee
lude98SH's Avatar
Yea that should free up some space
Old Oct 20, 2006 | 10:55 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">once you remove the old one, to save you all the hassle of putting it back, put a smaller IM in this time...ie. euro-r hehee </TD></TR></TABLE>
Haha i wish
Old Oct 20, 2006 | 11:04 PM
once you take off the IM support bracket there is a lot of room.
Old Oct 21, 2006 | 06:11 AM
lude98SH's Avatar
Default Re: (94vtirozguy)
There isnt any room to get in there to disconect the IM bracket. Theres coolant line, vacumm lines, the a wiring harness all in the way going from up top. And underneath there no way i would have to unbolt the exhaust, and drop the support there that connects to the LCA, steering rack and rear motor mount. I seriously have no space i dont know how anyone has plenty of room because i dont even have room to take the stuff of to make more room.
Old Oct 21, 2006 | 06:16 AM
lude98SH's Avatar
Default Re: (lude98SH)
This is all I found on the subject. It seems that on the base you guys are able to do this differently.
https://honda-tech.com/zerothread?id=1590426
Old Oct 22, 2006 | 07:38 AM
lude98SH's Avatar
bump
Old Oct 22, 2006 | 03:19 PM
BlUAc's Avatar
have you tried using 1/4in tools to move around a lil better you dont have muck leverage with one but they aren't on very tight
Old Oct 22, 2006 | 03:38 PM
lude98SH's Avatar
Default Re: (BlUAc)
Yes thats what i was using the whole time. I couldnt imagine trying it with 3/8 drive
Old Oct 22, 2006 | 04:20 PM
Revi's Avatar
Default Re: Taking IM off ? (MadCityLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">Remove the black vaccum box and support brace? With those out there should be plenty of room.</TD></TR></TABLE>
Old Oct 22, 2006 | 05:07 PM
lude98SH's Avatar
Default Re: Taking IM off ? (Revi-Ra)
I cant even get to that.
Old Oct 22, 2006 | 05:13 PM
MadCityLude
Guest
Posts: n/a
^^ yes you can, your just trying the wrong angle or something.
Once you get this your going to feel real stupid
You just need to look at it differently
Old Oct 22, 2006 | 05:23 PM
lude98SH's Avatar
Yea i know thats usually how it works. But i cant see anyway. Have you done this on an SH, because I hear its a totally different aproach ?
Old Oct 23, 2006 | 06:30 AM
lude98SH's Avatar
bump
