ported Euro R IM expected numbers
I'm a Jackass
From: who knows.. the shadow knows, CA, United States
Has anyone ported out the euro R IM, and dyno'd. I have a 2000 euro R H22A in my 97 prelude, and am planning on porting that thing way the hell out, and getting a match ported TB. What numbers would the euro R IM make when its ported? anyone?
I'm planing on doing something similar, not really porting, but more like smoothing. If you notice inside the runners you can see the casting along the sides. I'm going to be sanding that out with 200 grit then 400 grit sand paper. I just dont know how far in I'll be able to go.
As for porting the im, I think its a bad idea, unless you turbo'ed or SC.
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 »</TD></TR><TR><TD CLASS="quote">i read somewhere that if you port&polish the mani too smooth you actually lose power because you mess up the airflow</TD></TR></TABLE>
You have a Euro R???
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 »</TD></TR><TR><TD CLASS="quote">yes i do
whats the tranny code?
</TD></TR></TABLE>whats the tranny code?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgonzbb1 »</TD></TR><TR><TD CLASS="quote">As for porting the im, I think its a bad idea, unless you turbo'ed or SC.</TD></TR></TABLE>
bad info. for forced induction it is just that. if FORCES air into the intake manifold so for a street car there is little to be gained from porting the intake mani. but for all motor you are trying to get as much air into the motor as possible with out getting too much. I wouldnt suggest porting the intake mani until you have some solid head work done....at least cams and a header. While you have it cracked open you might as well port and polish the head...then that ported intake mani will become much more handy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeekH22#2 »</TD></TR><TR><TD CLASS="quote">
whats the tranny code?</TD></TR></TABLE>
well, i have an H22a4 with euro-r internals (cams and pistons) including the mani...i'm running a M2B4 so it's not a "real" euro-r but euro-r specs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeekH22#2 »</TD></TR><TR><TD CLASS="quote">Has anyone ported out the euro R IM, and dyno'd. I have a 2000 euro R H22A in my 97 prelude, and am planning on porting that thing way the hell out, and getting a match ported TB. What numbers would the euro R IM make when its ported? anyone?
My euro R on my street car was cut in 1/2 ported and rewelded by endyn and made gains across the board sorry no dyno's avail. Its all in who ports and does the work IMO if its done correctly you will get more gains then stock. There is room for improvment on a stock unit if done right.
coomplife05
Aug 13, 2013 06:36 AM
coomplife05
Aug 9, 2013 02:07 PM
coomplife05
Aug 8, 2013 04:58 PM
