Whats the highest rpm toda valve springs are design to handle????????
Old May 3, 2002 | 07:00 PM
powerfulperformance's Avatar
Default Whats the highest rpm toda valve springs are design to handle????????
Top ^^^^
Old May 3, 2002 | 07:02 PM
TypeR0149's Avatar
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (powerfulperformance)
if you want a ultra stiff spring go with kawasaki. I took my old car to 11,000 rpms before. I think the toda's can hadle upwards of 9500rpms, with stock retainers.
and honestlyt why would you want to go any higher than the pwerband of the cam
Old May 3, 2002 | 07:03 PM
TodaSi's Avatar
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (Vegeta)
ditto
Old May 3, 2002 | 11:03 PM
Austin's Avatar
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (TodaSi)
When I had the PowerFC it once read a peak-hold number of 9800rpm ...had the rev limiter set a little too high that day Toda valve springs, toda "B" cams, and Portflow Ti retainers.
Austin
Old May 4, 2002 | 05:30 AM
Mr Hammond's Avatar
a/k/a Jomo
Portflow retainers, Toda Springs and some valve guides and you can go to 10,000...but then again even the Spec C's only make power to about 9,600rpm.
Later
Old May 4, 2002 | 05:32 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (Mr Milano)
Lauging at my previous statement..."only make power to about 9600rpm like its no big deal"
Later
Old May 4, 2002 | 07:10 AM
gsr98vtec's Avatar
10,000 rpm if you do it right, ask sgT
Old May 4, 2002 | 09:16 AM
Mr. Softee's Avatar
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (gsr98vtec)
ferrea valve springs can handle some serious rpm
Old May 4, 2002 | 05:57 PM
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (94goldjungsr)
I have spec C's and I don't plan on reving to 10,000. I just want to know what toda valve spring are design to handle, and i have portflow titanium retainers by the way............
Old May 4, 2002 | 06:02 PM
TodaSi's Avatar
That's my set-up. Took it to 9250 rpm many, many times. BTW, my timing belt broke (after 18,000 miles, not 15,000 miles like I stated before) so I'd suggest buying a Power Enterprises belt Worth the piece of mind.
Old May 4, 2002 | 06:53 PM
CRVRX's Avatar
I have used Eibach valve springs on my last few motors. Endyn sells them and says they are rated at 10,000RPMs at 13mm of lift. I have them with Ferrea ti retainers and I've run to 9,800 a few times. Endyn uses them on every motor they build.
Old May 4, 2002 | 06:56 PM
sgT's Avatar
sgT
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (CRVRX)
Then maybe they are the same ones Larry sold me that collapsed on me.
Old May 4, 2002 | 07:00 PM
SEFIxCivic's Avatar
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (sgT)
i thought endyn used the web valvetrain kits? was the ones that collapsed on you the ones that have smaller diameter springs/retainers/seats?
Old May 4, 2002 | 07:04 PM
sgT's Avatar
sgT
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (SEFI8LOxCivic)
smaller they were, yes
Old May 4, 2002 | 07:12 PM
SEFIxCivic's Avatar
oh damn, that sucks. yea, those are web kits, which part failed? what cams were you running? and how many rpm? thanks.
Old May 4, 2002 | 08:01 PM
sgT's Avatar
sgT
toda spec C, no high rpm as the motor was being broken in, at most 6-7000rpm.
all of the outer springs broke into pieces.
Vtec integra's Avatar
i revved my b's with the toda valve train with the je 12:5:1 compression pistons to 9500 consistantly. oh yea i also rigged my oil pump to push out more pressure than the stock setting so its safer.
Old May 4, 2002 | 08:02 PM
sgT's Avatar
sgT
Default Re: Whats the highest rpm toda valve springs are design to handle???????? (Vtec integra)
more pressure doesnt mean safer, more pressure just means more force to blow seals
Old May 4, 2002 | 08:05 PM
well i think its safer with the set-up i got.
Old May 4, 2002 | 08:10 PM
sgT's Avatar
sgT
and what you dont know cant hurt you right?
Old May 5, 2002 | 05:16 PM
HYPERTUNE-Mark's Avatar
I have spec-C cams with Toda valve springs and my rev limit is 10,000. I have seen 10,500 on the datalog many times due to the soft rpm limit. In fact, when I burn out, it shows 10,500rpm for around 4-5 seconds.
My opinion is that Toda valve springs are probably the best you can get for a B series engine. Not many companies use the more expensive egg shaped spring, and Toda do it for a reason.
janiscrulzz
K Series
Nov 13, 2016 09:03 AM
baysic r
Jun 29, 2009 11:49 PM
Terrible One
Oct 31, 2004 12:16 PM
Slow96RedEk
Jan 15, 2004 04:43 PM
Integra-DC5
Aug 19, 2002 06:59 PM
