200 Accord Lock actuator
The front right door lock on my Accord stopped working when press the remote. Does anyone knows where can buy the lock actuator?
is it necessary to buy the lock assembly or just the actuator?
product cheapening dept. took over on the door lock actuators.
They are a real common fault. The big hassle of replacement is that the entire latch assy needs to be removed so you can get to the screw on the bottom of the actuator. Be really careful popping loose the rod that goes to the exterior door handle, very easy to break the lever on the handle.
dbailey
Apr 26, 2017 02:47 PM
