Light Bulbs??
Old Oct 15, 2006 | 01:12 AM
Socratez's Avatar
Default Light Bulbs??
This may be a stupid question but I am wondering if I can just change my lightbulbs for something brighter without any other modification? Can I just purchase the Nighthawk's from the local automotive store and pop them in? I know it is probably a long shot but I am curious if it is possible. I do plan on doing a full HID light conversion but not right now where I am doing suspension and exhaust.
Any help is appreciated ...
Soc
Old Oct 15, 2006 | 01:14 AM
knockout's Avatar
Default Re: Light Bulbs?? (Socratez)
of course you can. just get the right type of bulb for your car.
Old Oct 15, 2006 | 05:45 AM
Eran's Avatar
HT White Ops
Get nighthawks. They ****** rock.
Don't get hids. They're not made for your car.
Read the Automotive Lighting, Color, and You sticky.
Old Oct 15, 2006 | 07:11 AM
Duane_in_Japan's Avatar
Default Re: (Eran)
I have only seen HIDs being installed, as far as I could see the entire wire system is in the kit with amps and other relays and controllers, it looks like there was no way to melt wires on the cars original harness, maybe you have seen crappy sets, this one kit was over $300.
Old Oct 15, 2006 | 07:48 AM
Eran's Avatar
HT White Ops
Default Re: (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">I have only seen HIDs being installed, as far as I could see the entire wire system is in the kit with amps and other relays and controllers, it looks like there was no way to melt wires on the cars original harness, maybe you have seen crappy sets, this one kit was over $300.</TD></TR></TABLE>
I don't care about wiring. You really must not understand how hids work if you think I mean you're going to melt wires .... that and calling a ballast and amp.
HID's suck in civics because they're not made for our cars. The reflector housing on a civic is designed for a dual-filament halogen bulb, not a single-core hallide lamp. Even with casper shields and whatnot, you still have odd cuttof and side glare.
Old Oct 15, 2006 | 09:06 PM
Socratez's Avatar
Are ther a set of housings for a Del Sol that would work with the HID's? Maybe a Black set with crystal clear housing? like this one here? Or should I just stick with Halogen bulbs? I read that guide but it was information overload. I am not a physicists by any stretch of the imagination ...
Here are the housings I am talking about ... Something like this maybe?
Old Oct 15, 2006 | 09:08 PM
wudini's Avatar
HID's pretty much NEED projectors to be effective, so no...those lenses would not work.
Old Oct 15, 2006 | 09:11 PM
HomicidalHatchBack's Avatar
you want bright nice lights go with piaa bulbs there really nice, very bright and white.
Old Oct 15, 2006 | 09:12 PM
Socratez's Avatar
Looks like there is a market for them ... maybe there are somthing out there? If not maybe something should be designed ... I guess I'll have to get that Physics Doctorate after all ... LMAO ... So the Nighthawks are a good Halogen? Clearvision, Nightvision, Weathervision .... Easy as pop in the new one take out the old one??
Soc
Eran's Avatar
HT White Ops
Default Re: Light Bulbs?? (wudini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wudini &raquo;</TD></TR><TR><TD CLASS="quote">HID's pretty much NEED projectors to be effective, so no...those lenses would not work.</TD></TR></TABLE>
Untrue, but the point is still gotten across.
D2S = projector HID (ie, S2000)
D2R = reflector HID (ie, IS300)
But even with D2R's in that, it's still not designed for HID, so it wouldn't work anyways.
Jhonny Ricer's Avatar
now now they do make a headlight for our car that supports an hid assembly and does make proper cutoff and so on only prob is the headlights cost 565 and some change a housing
Old Oct 15, 2006 | 09:13 PM
Eran's Avatar
HT White Ops
Nightvision and Weathervision are coated.
Boo.
Nighthawks.
Yay.
Old Oct 15, 2006 | 09:14 PM
Eran's Avatar
HT White Ops
Default Re: Light Bulbs?? (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">now now they do make a headlight for our car that supports an hid assembly and does make proper cutoff and so on only prob is the headlights cost 565 and some change a housing </TD></TR></TABLE>
It's not just the housing. The TYC one-piece hid retrofit comes with D2S bubls, housings, ballasts, wiring harnesses, and a new wiper fluid resivoir that you can bolt the driver's side ballast to.
Old Oct 15, 2006 | 09:43 PM
Socratez's Avatar
I don't own a civic though ..... the Del Sol lights are way differnt then the Civic ones and I don't think I'll be doing a frontend conversion just for some brighter lights ..... Unless I am mistaken ?!
Old Oct 15, 2006 | 09:44 PM
racer_X_123's Avatar
Default Re: Light Bulbs?? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">HID's suck in civics because they're not made for our cars. The reflector housing on a civic is designed for a dual-filament halogen bulb, not a single-core hallide lamp. Even with casper shields and whatnot, you still have odd cuttof and side glare. </TD></TR></TABLE>
I must dissagree... best money i have ever spent! and it was so easy!
EJ8 GSR-T
Dec 25, 2006 09:34 PM
gyrmaersk
27
Jun 20, 2006 03:05 PM
DC2_2
Jun 6, 2006 11:09 AM
dc2lun
Jan 2, 2004 10:27 PM
Sonnboy18
Aug 25, 2003 06:47 AM
