Need some help w/ accord radio harness wires...description
Old Oct 14, 2006 | 10:28 PM
mxl36o's Avatar
Default Need some help w/ accord radio harness wires...description
the four wires on the left... I need to know its purpose, because I cant seem to figure out what it connects to.
btw http://www.installdr.com/Harnesses/HA-Wiring.pdf doesn't help cause it doesn't even match up
Old Oct 14, 2006 | 10:31 PM
iam7head's Avatar
Default Re: Need some help w/ accord radio harness wires...description (mxl36o)
year of the harness?
more info
Old Oct 14, 2006 | 10:41 PM
mxl36o's Avatar
Default Re: Need some help w/ accord radio harness wires...description (iam7head)
sorry its a 99 accord (blue plug).... the white is the older honda plug, i'm converting to the newer honda plugs.
Old Oct 15, 2006 | 12:56 PM
philadd's Avatar
Red/black - Dim control (+)
red - Dim control (-)
I can't remember the blue, and I don't remember seeing 2 black wires, so I can't help you with that either. The dim control wires I'm sure of.
Old Oct 15, 2006 | 05:31 PM
standbackimapro's Avatar
Dim Control ( aka When you turn your parking/headlights on it dims out the radio lights)
Old Oct 15, 2006 | 07:41 PM
SuShiBoiiii's Avatar
damn ever heard of butt conectors
Old Oct 15, 2006 | 08:17 PM
mxl36o's Avatar
i figured out... thin black one is AMP ground, red w/ black is dimmer, the other two I dont need...
Thanks
Old Oct 15, 2006 | 10:21 PM
philadd's Avatar
Default Re: (mxl36o)
The dimmer uses 2 wires... one for positive, and one for negative. You need both.
EDIT: Well, maybe you won't need both. I never looked at how older gen Accords (5th gen and older) were wired...
rustlude87
Nov 1, 2009 05:50 AM
patrick4588
Engine Management and Tuning
May 24, 2008 04:19 PM
suno
Apr 14, 2008 06:02 PM
blackandblue
Dec 29, 2005 01:14 PM
weak_tec
Jul 17, 2005 05:04 PM
