dash lights out??
Old Oct 14, 2006 | 04:20 PM
white ej2's Avatar
Default dash lights out??
i recently installed a tach and i hooked up the "light wire" to my dash light dimmer and it was working fine.. and now only the tach light works and not my dash lights
i also cleared the codes in my ecu if that has anything to do with it??
Old Oct 14, 2006 | 05:41 PM
white ej2's Avatar
Default Re: dash lights out?? (Littlesriz)
anyone???
Old Oct 14, 2006 | 07:46 PM
white ej2's Avatar
Old Oct 14, 2006 | 07:53 PM
95jeremie's Avatar
what year car? ex,dx what (trim)? what gauge? need all this info
have you tried rotating the dimmer to see what happens? i know on my car i have them hooked up so that i can turn my gauge light on and my dash lights off or vise verse. have you gone back and double... triple checked your wires?
Old Oct 14, 2006 | 08:07 PM
ek4__'s Avatar
Default Re: dash lights out?? (95jeremie)
maybe you blew the dimmer switch??? had the same problem...some how my switch blew and all my interiors died. just take your dimmer out and look at the chip inside to see if there are any burnt spots.
white ej2's Avatar
1994 dx.. aftermarket gauge since there wasnt one to begin with.. dimmer isnt working b/c the lights dont work.. the only lights in the dash that dont work tho are the basic speedometer, fuel, and temp everything else works... everthing worked after i installed the tach too but now all of a sudden its not
Old Oct 14, 2006 | 08:11 PM
white ej2's Avatar
Default Re: dash lights out?? (ek4__)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4__ &raquo;</TD></TR><TR><TD CLASS="quote">maybe you blew the dimmer switch??? had the same problem...some how my switch blew and all my interiors died. just take your dimmer out and look at the chip inside to see if there are any burnt spots.</TD></TR></TABLE>
my tach light is connected to the dimmer and it works and so do all my interiors.. i already checked it.. i even unhooked the tach wire to see if it was interfering and it was the same
Old Oct 14, 2006 | 09:17 PM
white ej2's Avatar
bump
Old Oct 14, 2006 | 09:19 PM
Eran's Avatar
HT White Ops
Chances are you fried the dimmer, as stated above. Your interior lights (dome light, courtesy lights, etc), but if your dash lighting is toast, then it's definitely your dimmer.
Old Oct 14, 2006 | 09:23 PM
white ej2's Avatar
Default Re: dash lights out?? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Chances are you fried the dimmer, as stated above. Your interior lights (dome light, courtesy lights, etc), but if your dash lighting is toast, then it's definitely your dimmer.</TD></TR></TABLE>
is that the actual dimmer switch itself that i would have to replace b/c the wiring behind it still works fine
Old Oct 14, 2006 | 09:34 PM
Eran's Avatar
HT White Ops
Yes, if the dimmer switch gets burnt out, then the dash lights stop working, even though all the lights are fine.
Old Oct 14, 2006 | 09:50 PM
white ej2's Avatar
im guessing that the tach hook up burnt out my switch... will it do it to the new one that i put in??
Old Oct 15, 2006 | 04:31 AM
white ej2's Avatar
Old Oct 15, 2006 | 03:17 PM
ek4__'s Avatar
well what kinda of tach are you using? if its a auto meter then you should of just ran the wires to fuses. first, fix the problem then replace it or else you'll just end up burning the new dimmer switch. also, did you check your fuses inside your car? that could just be it too.
Old Oct 15, 2006 | 03:33 PM
white ej2's Avatar
i already checked the fuses and theyre fine.. watd u mean by auto meter??
Old Oct 15, 2006 | 04:09 PM
95jeremie's Avatar
Default Re: dash lights out?? (white ej2)
what brand tach we know that it's an aftermarket but what brand?
Old Oct 15, 2006 | 04:25 PM
white ej2's Avatar
i forget.. it was some 2" tach that i got for cheap off ebay
OklahomaEg
Mar 6, 2013 09:31 AM
hondafreak2134
Oct 10, 2009 05:24 PM
93hatchdude
Aug 28, 2007 09:11 PM
TheJuggalo
Sep 3, 2002 12:35 PM
