88 vs 89
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16civster »</TD></TR><TR><TD CLASS="quote">no
and why not then?
</TD></TR></TABLE>and why not then?
No real difference except how the rear struts attach to the control arm. the control arm can be switched out, too.
There is one other difference. The length of the arm that adjusts toe in the rear. On the 88 it's shorter, causing more passive steering and thus more lift throttle oversteer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee »</TD></TR><TR><TD CLASS="quote">No real difference except how the rear struts attach to the control arm. the control arm can be switched out, too.
There is one other difference. The length of the arm that adjusts toe in the rear. On the 88 it's shorter, causing more passive steering and thus more lift throttle oversteer.</TD></TR></TABLE>
actually its the position of the mount ont the chassis to adjust the toe...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee »</TD></TR><TR><TD CLASS="quote">There is one other difference. The length of the arm that adjusts toe in the rear. On the 88 it's shorter, causing more passive steering and thus more lift throttle oversteer.</TD></TR></TABLE>
Hmm I knew somthing there was different but I wasen't sure the result of it. Is this something i should be worried about or can fix?
Besides the rear lower control arms and rear struts being slightly different, the rest of the suspension is the same.
88 model SI's made 105hp, but they were also lighter than newer years too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 »</TD></TR><TR><TD CLASS="quote">Hmm I knew somthing there was different but I wasen't sure the result of it. Is this something i should be worried about or can fix?</TD></TR></TABLE>
i love the handelimg of the 88si with a nice suspension it handels awesome...
mad pup
18
Feb 3, 2009 03:14 PM
alexdog69
Jun 13, 2005 09:10 PM
HamiltonRex
Apr 12, 2004 10:46 AM
