help with spark plugs
Old Oct 14, 2006 | 03:39 PM
justanek9's Avatar
Default help with spark plugs
i just bought some ngk spark plugs and i wanted to know what the gap is supposed to be for them. they are for a 95 jdm gsr motor, thanks.
Old Oct 14, 2006 | 04:06 PM
inspyral's Avatar
Stock gap should be 1.1mm or .044"
Old Oct 15, 2006 | 09:22 AM
Duane_in_Japan's Avatar
Default Re: (inspyral)
They are pre gapped to match the engine they are designed to go in, make sure you have the correct part number and eyeball all the gaps, if they look good, all 4 cant be out of spec. 1.1 is most popular NGK gap, the part number contains the heat range, even more imprtant, buy what you need by the book.
Rob.
May 6, 2009 01:31 PM
civicboy95
Mar 10, 2009 01:13 PM
xiaogou
Nov 21, 2007 01:37 AM
jdmitr01
Oct 8, 2004 09:57 PM
Legendaryyaj
Nov 21, 2003 02:31 PM
