90 CRX Si rear disc conversion on a 90 Civic Si?
i have the chance to buy the trailing arm w/ rear disc set from a 90CRX Si. is this gonna fit on my 90 EF? or do only the DA rear discs/trailing arms work for it?
i tried a quick search but came up with nothing good.
thanks!
Modified by funkified at 4:53 PM 10/14/2006
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaNnYsEvEn »</TD></TR><TR><TD CLASS="quote">this is like the 100000000000 thread just this week alone on this topic...please search
thank you</TD></TR></TABLE>
believe me, I just did a search right now because im need info too. My results only came back with for sale post. On top of that, it does not take any efford to help out for a few minutes and answer the OPs question. For my question; would crx disc brakes fit my 88 civic sedan?
all the search results were for crx or hatches. I guess disc brakes conversions is not that famous on sedans. Again, would crx rear disc brakes fit on my 4 door civic sedan?
https://honda-tech.com/zerothread?id=1393099
https://honda-tech.com/zerothread?id=1334534
https://honda-tech.com/zerothread?id=578735
https://honda-tech.com/zerothread?id=234443
this was all found within just seconds.
how to search:
where it says "search for", put what your looking for.
where it says "data set" click archived (since most of this stuff has been covered before in the past, thats where it will be)
where it says "forum", in your case,use the crx/EF civic forum.
where it says "creater" put whatever member you want. (i just leave that blank)
where it says "search in" you can use either or, but it works alot better with topic titles.
where it says list order, i just leave that alone too.
i dont see why it wouldnt work, you might need to use longer e-brake cables.
how to search:
stefz
Oct 27, 2008 09:40 AM
hebelect
Sep 21, 2004 08:39 PM
